engine whine
Old Mar 27, 2009 | 10:49 PM
bigkat91's Avatar
bigkat91
Unhappy engine whine
i have a really loud whine coming from my engine. when i got home i took of the engine belt and the noise is still there any ideas? im goint to pull the intake manifold and exhust manifols to see if the gaskets are bad...
Old Mar 27, 2009 | 11:14 PM
95_318SLT's Avatar
95_318SLT
maybe the water pump? (just throwing out the first idea that popped into my mind). It's kinda hard to give good advise on something we can't hear.
Old Mar 28, 2009 | 09:09 AM
bigkat91's Avatar
bigkat91
yea i might be starting my re build sooner than i thought. the noise is there when the engine belt is off so i dont think its the asscessories
Old Mar 28, 2009 | 12:36 PM
RockGuardedDak's Avatar
RockGuardedDak
could be a vacuum leak somewhere, or intake leak
Old Mar 28, 2009 | 01:25 PM
fox's Avatar
fox
If its a bearing the whine will increase with engine speed you can also use a stethoscope to listen where the whine is coming from. Another possabily could be the oil pump drive gear is wearing out.
Old Mar 28, 2009 | 03:13 PM
bigkat91's Avatar
bigkat91
I hear the whine more when i let of the gas but this morning i went to start it up and the whine was gone......clueless
Old Mar 28, 2009 | 06:23 PM
fwtc's Avatar
fwtc
don't tear anything apart just yet. i've started my truck in -40c (-40f, the same) and i could hear a loud wine at idle but decreased at higher rpm. the cold tightened up the power steering pump belt and made it wine, once it was warmer it was ok. i would first check for proper tension on the belts, then check the power steering pump and water pump bearing. like fox said you should be able to locate a bad bearing with a stethoscope. if you don't have one then a long metal rod (3/16 will do) against your ear and the part you want to check will tell you.
i always check the cheap things first and work from there. you don't want to spend 500 bucks for a 5 dollar part (did it myself lots of times)
Old Apr 13, 2009 | 01:30 AM
bigkat91's Avatar
bigkat91
the thing is that the whine is there with the belt off everything..
Old Apr 13, 2009 | 01:49 PM
1shotjake's Avatar
1shotjake
If I remember correctly there was a recall on the oil pump gear... I think they were prone to wearing out much too soon. I would start there.
