check engine light codes
Old Mar 31, 2009 | 07:11 PM
88longbed's Avatar
88longbed
Default check engine light codes
hey guys. taking a look at some of that exhaust air pump and i decided to check to see if my truck was return any codes.
the CEL comes on when the key is turned to the on position like normal. after it goes out initially, it blinks 1 2 3 3 5 5
i thought 5 5 meant the end of the sequence, but i also thought i should see 8 8 before anything else.
Old Mar 31, 2009 | 07:19 PM
95_318SLT's Avatar
95_318SLT
Whenver you post something up about engine codes, it helps us out a lot if you say what the codes are, not just the numbers.
12 is a pointless code, it just means the battery has been disconnected recently.
33 means you have a problem with the A/C clutch relay
55 is end of codes.
There is no code 88, what did you think should pop up?
Old Mar 31, 2009 | 11:57 PM
fwtc's Avatar
fwtc
the haynes manual says 88 is the start of the test but i've never seen it and i'm pretty sure no one else has, so i wouldn't worry about it.
Old Apr 1, 2009 | 01:53 AM
RockGuardedDak's Avatar
RockGuardedDak
ive never gotten the 88 code. mine always just stays on for a bit, then turns off, then starts the sequence and ends with 55
Old Apr 1, 2009 | 07:55 PM
88longbed's Avatar
88longbed
55 is end of codes.
sorry, dude. i posted the numbers right after walking in the house so i didn't forget them while deciphering their meaning.
