leak!!!
Old Apr 28, 2009 | 11:53 AM
s4m1am's Avatar
s4m1am
Default leak!!!
so every where i park my truck will leak a drop or two from the front main seal. not alot but consistant. im not in the mood to do a main seal happen right now is there any preventive additive that may stop/slow the drip. it just started doing this in the last week after a oil change.
Old Apr 28, 2009 | 12:34 PM
RockGuardedDak's Avatar
RockGuardedDak
are you positive that its the rear main seal? since you said that it started happening after you did an oil change, it sounds alot like you just didnt properly tighten the oil pan bolt.
Old Apr 29, 2009 | 12:12 PM
s4m1am's Avatar
s4m1am
oh come on now i might be new to the forum but im not that dumb. i worked at a oil change shop for a year. its not the rear main seal its contained to the very front of the oil pan just behind the bottom pully wheel.
Old Apr 29, 2009 | 12:40 PM
RockGuardedDak
hey, i said that i wasnt trying to make you look stupid, i didnt doubt that your not dumb, i just wanted to eliminate the obvious.
look for "lucas heavy duty oil stabalizer", use what you think it about right for sealing the seal. it recommends no more than 60% of the bottle tho.
Old Apr 30, 2009 | 01:07 AM
s4m1am's Avatar
s4m1am
3.9 sorry i wasnt tryin to be snappy.
i went to car quest and did just that i put some sealer in and got back from driving around after putiting the lucas in and i relise that what is dropping in my drive way is not oil but coolant. its dripping from the front of the engine and its not from the thermostat area .
head gasket?
what else can i check before i tear into it?
Old Apr 30, 2009 | 01:14 AM
95_318SLT's Avatar
95_318SLT
Check the lower radiator hose. Mine leaks from there from time to time (its a very random and annoying problem).
Old Apr 30, 2009 | 01:15 AM
dbilik's Avatar
dbilik
Check water pump and the little hose behind the water pump (if you can see in there good enough), and the metal tube. I had a leak in this area and the fan blew it all over, was not obvious right away as to where it was coming from.
Old Apr 30, 2009 | 09:49 AM
RockGuardedDak
+1 on that.
but also make sure its not coming from behind the water pump pulley. when mine went, thats where the problem had started. if it is coming from behind there, replace the water pump ASAP (i didnt, and my water pump literally blew up when i was warming up the engine one morning...)
Old Apr 30, 2009 | 02:58 PM
s4m1am's Avatar
s4m1am
yea its the water pump. last night it was more than just a drop.
Old Apr 30, 2009 | 04:35 PM
pashadowops's Avatar
pashadowops
I gotta laugh cause that happened to me once. It was on my 1969 Delta 88. I was on my way to the beach when I saw a huge cloud of steam come from under the hood. When I was able to open the hood, I saw the pump had disintegrated and the fan had made a perfect circle through the radiator. I wasn't laughing then but, in retrospect it's pretty funny.
