Carb help
Old Apr 29, 2009 | 03:46 PM
Dakota1089's Avatar
Dakota1089
Default Carb help
does anyone know if an Edelbrock 600 cfm avs carbwill fit on a 1990 318 TBI. Just get rid if the TBI and throw that on if it works
Old Apr 29, 2009 | 05:12 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No I don't believe it will. And you will need a intake manifold and carb and the correct distributer and. I can't remember what year your truck is but if it has fuel injection you will need to take out the fuel pump too.
Old Apr 29, 2009 | 05:46 PM
Dakota1089's Avatar
Dakota1089
dang that sux, What about that same carb on my 88 3.9L w/ the holley on it?
Thanks
Old Apr 29, 2009 | 06:23 PM
OneBadKota's Avatar
OneBadKota
Yes, it should bolt right on the 88.
Old Apr 29, 2009 | 06:24 PM
OneBadKota's Avatar
OneBadKota
FWIW try to avoid Carburation with that 10% Ethanol crap they're putting in gas now, it eats the insides of the carb and if you drive it ALOT you'll be rebuilding it every year.
Old Apr 30, 2009 | 12:30 AM
Dakota1089's Avatar
Dakota1089
Isnt that only certain fuel companys that do that or certain fuels or is it all now? Cuz i found this carb new for like $100 and its like a $500 carb
Thanks
Old Apr 30, 2009 | 12:56 AM
95_318SLT's Avatar
95_318SLT
I know a lot of companies are putting ethanol in their gas, but there are still a few that don't do that crap. I always fill my truck up with nothing but 93 octane Shell gas, cause their gas is "nitrogen enriched" and contains no ethanol... at least there's no reference to ethanol on the pumps.
Old Apr 30, 2009 | 01:16 AM
Dakota1089's Avatar
Dakota1089
I tried looking on they're site but do you know if the carb (edelbrock avs 600 cfm carb) is a 2 or 4 barrel. I would like to put it on my 88 dakota 3.9 carburated or the guy also has some weiland intake manifold for a 318...so since i am building a 390 stroker out of a 318 i might just get the manifold and carb?
Thanks
Old Apr 30, 2009 | 11:23 AM
OneBadKota's Avatar
OneBadKota
I would assume it's a 4bbl. I would recommend the Edlebrock Air Gap intake though.
Old Apr 30, 2009 | 12:44 PM
Dakota1089's Avatar
Dakota1089
Is that a better manifold or what is that?
Thanks
