IGNITION is pissing me off!!!!!
Old Apr 30, 2009 | 11:39 PM
  #21
Dakota1089's Avatar
Dakota1089
I havent looked into it but i was reading and i did see something like that come up so i will have to try and find it again, otherwise there are some good tranny shops around me and i will see f i can get it bulletproofed for not too much loot.
Old Apr 30, 2009 | 11:53 PM
  #22
Dakota1089's Avatar
Dakota1089
Also i just read your tranny swap thread and what thread lock did you use on your helicoils... I had to use them for one of the thermostsat inlet bolts and did not use any i know i was supposed to but i have jus been tightening it every so often but would like to put lock on it
Thanks
Old May 8, 2009 | 12:07 AM
  #23
Dakota1089's Avatar
Dakota1089
So i want your guys thoughts on this i hink i found the problem. The other day it wouldnt start for awhile and my drive way is inclined so i put it in neutral and let it roll and it started. But today it wouldnt again and i tried that, then while in park i returned the key in the off position let of the brake and turn the key back a quarter turn then hit brake and it turns over so i think its the ingnition switch??
Thanks
Old May 8, 2009 | 12:36 AM
  #24
95_318SLT's Avatar
95_318SLT
Thanks
I actually don't know what kind of thread lock it was, except that it was red. But the thing about helicoils is that you can't back them back out to put threadlock on them. But if you're just trying to put thread lock on the bolts, it should hold it all together. I would assume any threadlock will work, maybe a high temp if that's even an option??
Old May 8, 2009 | 12:40 AM
  #25
95_318SLT's Avatar
95_318SLT
Thanks
I really still think its the park/neutral saftey switch. It dosen't cost much and it's easier to change than the ignition switch, so you should start there. It probably has to be one of the two, but if it were me, I'd start by putting in a new park/neutral switch and go from there. Just my $0.02, take it or leave it.
Old May 8, 2009 | 02:08 AM
  #26
dodgerules86's Avatar
dodgerules86
As 95_318SLT said, you can start in park or neutral. When I initially replaced my transmission, I had to put the lever in Neutral or shove it up into Park, but now it works fine.
But, from what your saying, its looking like the ignition switch.
Old May 8, 2009 | 12:17 PM
  #27
Dakota1089's Avatar
Dakota1089
From looking through my service manual i dont want to do the ignition switch it looks a little like a pain. ill start with the neutral saftey switch and let you guys know. As For the thread lock thats what i was told to use to but i dont know the names just that its this red high temp stuff.
Old May 9, 2009 | 12:45 AM
  #28
qevans's Avatar
qevans
hate to say it but sounds like the ignition switch and its a little of a pain to change it but not to bad.
Old May 13, 2009 | 03:09 PM
  #29
Dakota1089's Avatar
Dakota1089
AHHH there is no figuring out what is wrong with this thing. So w/ the idea it was my ignition swith i removed that and sure enough 1 or the copper connections was curroded* so i cleaned that up and put it back together and it stated up no problem al day yesterday and this morning when i went somewhere. When i was leaving it would not start again???? So i put it in and out of park nothing... Then i put it in neutral and it started over... Ok. Then at home i went to move it in the garage and again nothing so while in park and in the forward position i wiggled the key and tryed starting at the same time and she started.. ureka?? So is that the park/neutral safty switch??
Thanks
Old May 13, 2009 | 03:19 PM
  #30
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it sounds like it's the park neutral safety switch. Cheep and easy.
