318 strocker kit info needed
Old 05-09-2009, 01:56 AM
injmopar's Avatar
injmopar
injmopar is offline
In the add it says that the crank is new in the box ,so it will have to be balanced to his rods and pistons or the ones you buy .Balancing a stroker crank can run in to big coin . That's why some unbalanced kits are alot cheaper .
  #22
Old 05-09-2009, 02:05 AM
95_318SLT's Avatar
95_318SLT
95_318SLT is offline
The way I understand it is you don't necessarily balance a crank to your rods and pistons, you balance everything seperately.
For the pistons and rods, they weigh them to the gram and pick the lightest of the 8 and drill out the others out to match. For the crank, I assume they spin it and drill it out as needed.... kinda like balancing a propeller, but I could be wrong cause I've never seen it done.
  #23
Old 05-09-2009, 09:05 PM
injmopar's Avatar
injmopar
injmopar is offline
For a 6 or 8 you balance the pistons against each other,then the big and small ends of the rods. Now you can calculate the bob weight which is attached to the rod journals .This simulates the weight of the rotating assembly when you spin balance it .But you are right if you are talking about a 4. With a 180 deg crank you have 2 pistons up and 2 pistons down so they balance each other out.
  #24
Old 07-01-2009, 06:05 AM
SPARTANENGINEER1701's Avatar
SPARTANENGINEER1701
SPARTANENGINEER1701 is offline
its great u guys take an interest in poly motors
all block from LA ENGINES WORKS EXCEPT--- pistons rear seal on ealy model
upp grade the oil supply ,solid cam and adj rockers,
dump the cast in take make an AL one and use a 650 ELD,carb,
headers MUST BE ON . remember this IEIEIEIE, AND THE HEADS ARE SEMI HEMI
but work great.
bad part comp is around 8.7 i think GO HAVE FUN
Quick Reply: 318 strocker kit info needed
