Electric water pump conversion
i think it is you that has the touched nerve sir, and i dont know if you have never been on a forum before or what, but you dont just go calling out everyone that has been on here for years and tell them to f off! i am in no way saying that we know more than you or anyone else on the forum for that matter, but have contributed many many more things here other than trying to make you see you are not making sense. i wish i had money to go out and buy this just to prove it will make a difference, why else would all of these race cars put electric water pumps AND electric fans in there cars if it did not give them some kind of performance gain? and not just poser racers but real racing teams!!!!!
http://www.superchevy.com/technical/...ump/index.html
This shows the Dyno reports for electric vs. mechanical. Also while explaining the differences between the two and the advantages of each. CSR says their pumps are recommended for street use also, meaning they must be pushing enough flow to keep the engine cool. I am curious to write them now and see exactly how much volume they are pumping and compare it to a stock water pump.
no problems. We all drive trucks, we can handle it.
Anyways, I didn't even see the other threads pop up before I posted the link. It is a very interesting article nonetheless. It isn't on a Dodge, sorry, but the concepts are the same.
Thanks Dennis!
I also just found that.
Notice it flows much less water than stock, that is where the gain is from, because it's not doing as much work, simply making something electric doesn't provide any gain. A set of under drive pulleys will give you the same effect. My main argument is that making something electric doesn't automatically free up power, doing less work frees up HP.
And wow, 6 whole HP at 6K and an average of 3HP across the board? Jesus christ that's massive. Totally worth the money
I have thousands of posts on at least a dozen forums. I kept it civil until 95_318SLT couldn't.
If you built an electric pump with a motor big enough to flow the huge volume of water equal to that of a belt-driven pump, it'd be so massive that you probably couldn't fit it under your hood
I don't have numbers based on two equivalent pumps, which is why the first example I gave was for radiator fans, cause they can be much easier compared... but the concept is the same.
So yes, an electric pump flows less, but that does not mean it is not ALSO more efficient.
And how am I not being civil? Because you keep throwing opinion after opinion at me with no factual evidence and I finally called you out for it and told you to research it? Or because I don't like being told that I don't know about "conservation of energy" cause I've only spend the last several years of my life learning about it? You can't keep telling someone off based on nothing but opinion without them eventually responding to it.
