Truck quits running on its own
Old May 22, 2009 | 08:00 PM
grtrat1's Avatar
grtrat1
Default Truck quits running on its own
New member here.. Looking for some help with this problem.. No one seems to know on the Dakota boards..
1994 Dakota 2wd ext cab 3.9 auto... I had a annoying exhaust leak and finally found out it was coming from that pipe that goes from the pass exhaust manifold to the back of the intake. It was split right by the tranny tube.. So I wiggles the pipe and it broke off the piece that bolts to the exhaust manifold. I took a short bolt and welded it to the opening of the piece that bolts to the exhaust manifold (left the pipe end alone).. Since then my truck has just quit running after about 10-15 of run time..I put it in park and it will crank right up..
Is this just a coincidence and maybe something else is wrong or do I need to replace that pipe?
Old May 22, 2009 | 09:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
That pipe is part of the EGR system. Exhaust Gas Recirculation system. I bet the valve on top is to blame. Or something in that system. Are you getting a check engine light?
Old May 22, 2009 | 09:46 PM
grtrat1's Avatar
grtrat1
no light... It just stops..As soon as I stop put it in park... It starts right back up..
