urgent!!!!!
Old Jun 2, 2009 | 10:19 PM
Ethan S's Avatar
Ethan S
Exclamation urgent!!!!!
ok heres the deal, i have been looking for a trans for my 96 dakota 3.9 since december. i have found some but not in my price range. if any one has any clue of where one might be, please let me know if you have one or know where to get one that is relatively close to northeren indiana, please let me know. the most i can probably come up with is 300 bucks. i know it isn't much but i need to get my truck running asap. and money is hard to come by, so please any leads any tips any links will be greatly appreciated.
Old Jun 2, 2009 | 10:25 PM
dbilik's Avatar
dbilik
What are you looking for? Manual or auto?
I have been looking for trannies for a while now, and I can tell you that you will be hard pressed to find one for $300 in good shape, not to say it won't happen, but if you have been looking for 6 months you might need to look into paying a little more. The cores are usually $200 - $300 alone if you need to turn one in.
Old Jun 2, 2009 | 10:28 PM
Ethan S's Avatar
Ethan S
i'm looking for an automatic and i know that's cheap but its the most i can afford
Old Jun 2, 2009 | 10:40 PM
dbilik's Avatar
dbilik
I understand the money thing, I would say keep an eye on Craigslist. You might be having to make a little drive too, check in WI, MN, and MI.
You might be able to get something in the $500-$600 range a lot more easily, and honestly, that is a good price I think.
Old Jun 2, 2009 | 10:59 PM
Ethan S's Avatar
Ethan S
alright thanks. i'm trying to save as much money as possible and that is a fair price. i'm just hoping for something cheap since they cut back my hours at work.
Old Jun 3, 2009 | 12:28 AM
murdered93'kota's Avatar
murdered93'kota
u could probably buy a truck that has a good trans for a low price also if u were willing to go that route
Old Jun 3, 2009 | 01:47 AM
dbilik's Avatar
dbilik
Here you go. Research and make sure it would fit, I am not too up on the auto trannies.
http://detroit.craigslist.org/pts/1199448960.html
Old Jun 3, 2009 | 12:39 PM
murdered93'kota
that trans wont work. it a 46rE, the trans u need is a a-518/46rH, u need a hydraulic transmission an electronic one will not work
Old Jun 3, 2009 | 08:55 PM
ZackN920's Avatar
ZackN920
Try goin through the junkyard, and look for one with lower or around your amount of miles on it,
and How much would it be for a rebuild?
Old Jun 4, 2009 | 01:34 AM
dodgerules86's Avatar
dodgerules86
No, he's got a 1996. The 42RE or 46RE will work.
42RE or 46RE can't be used on 1995 and below trucks.
42RH and 46RH can't be used with 1996 and above.
2WD transmisisons WILL NOT work with 4WD, and 4WD transmissions will not work with 2WD.
Since he has a 42RE in there, he can use one out of: a 42RE from any 1996-(whenever they stopped using the 3.9L V6) Dodge Dakota or Ram.
He can try using a 46RE from a 1996-(whenever they stopped using the 5.2 or 5.9L) Dakota, Ram and Durango.
