'95 SLT 318 turns over, won't start.
Old Jun 4, 2009 | 10:54 PM
FrostbiteBOB's Avatar
FrostbiteBOB
Angry '95 SLT 318 turns over, won't start.
Hi All, new to this and need your help. I drove my truck to work in the morning - everything normal. When I came out after work I tried to start it but it just cranked and would not start.
I read here on the forums about the ASD relay and checked that I had 12V to terminal 30 with ign off, power to 86 with ign. on, etc.,etc. That all showed as good.
Do I need to reset the Auto shut down? If so, how is it done on a '95?
I also swapped the starter relay which proved good(the engine DID crank) with the ASD relay but no luck.
Any ideas will be greatly appreciated!
Thanks,
Bob
Old Jun 4, 2009 | 11:16 PM
95_318SLT's Avatar
95_318SLT
Check the fuel pump relay and make sure the fuel pump is turning on and welcome to the forum!
Old Jun 5, 2009 | 02:32 AM
dbilik's Avatar
dbilik
Welcome welcome.
When you say turn over you mean the starter cranks over right? But the truck never actually starts right? If so I put my guess on the infamous splice under the power distribution center.
Also, check what 95_318SLT stated above, they are all kind of related in diagnosing the problem.
Old Jun 11, 2009 | 11:34 PM
kro10000's Avatar
kro10000
an easy way to tell if its a fuel or electrical\ignition problem is pour a little gas (or a little ol starting fluid) down the TB and see if shell start... I had a a problem with mine, turned out to be the ignition coil going south...
Old Jun 21, 2009 | 06:19 PM
FrostbiteBOB
After some testing I found that the ignition was firing but no fuel pressure. Checked all the splices under the fuse box underhood and all were fine. Removed the bulkhead electric connector @ the firewall and all connections looked good. Methinks this is a grounding problem! Will check that next.
Old Jun 21, 2009 | 11:28 PM
dbilik's Avatar
dbilik
Also check the fuel pump relay in the power distribution center.
Good to hear you are making progress though on finding the problem.
Old Jun 26, 2009 | 10:34 PM
FrostbiteBOB
After testing everything I could think of I had the truck towed to a repair shop. They confirmed it was a bad fuel pump. $577 later my Dakota is on the road again.
Why in hell can't auto makers figure out how to place the fuel pump outside the tank?
Old Jun 26, 2009 | 11:41 PM
skyshark186's Avatar
skyshark186
They can. But then who would get your 577 dollars if not a repair shop?
At least your up and running again. Gotta feel good to be back on the road.
Old Jun 27, 2009 | 10:58 PM
FrostbiteBOB
Sorry sksy ... but you don't get it.
I live in ALASKA. What if I'm 100+ miles offroad and this damned fuel pump fails with no warning?
THAT could be life-threatening! At least the old pumps gave you some warning of failure.
Old Jun 27, 2009 | 11:26 PM
95_318SLT's Avatar
95_318SLT
Wow dude, lay off him! There may not be any factory options, but go to a site like summitracing.com and buy a universal 22 gal fuel cell and external pump, hook them up and let it ride if your that worried about it.
