question about lift kit
i got a 1995 dakota 3.9 auto, standard cab short bed..question is , how do i go about getting a lift kit..i just wanna raise it about 2-4"..i know nothing about truck lift kits..im a muscle car guy..this is my daily driver, all i know i wanna raise this truck..whats the best route to go about this..
thank you
thank you
I'm guessing 4wd! You didn't say. It depends on what you want to spend, and how much work you want to do. We have all the lift options located in the FAQ2 in this section.
4wd
Body kit 2in.
http://store.summitracing.com/partde...5&autoview=sku
Custom 6in body kit. https://dodgeforum.com/forum/1st-gen-...y-tires-d.html
Full suspension kit 4in. ($1,700)
http://www.rockymountainsusp.com/dodge_dak4WD.htm Here is a great site about installing the kit. http://www.walt-n-ingrid.com/modifications.html
http://home.earthlink.net/~btm0106/ (Site down, may be up at sometime)
Lift keys 2 inch. Lots listed on
http://www.ebay.com/ 97-up may work!
http://www.totalperformanceonline.co...1321/50/100-14
Or you can just crank your torsion bars and add rear blocks for 1 inch or so.
You can tack weld some 1/4 inch steal strips to your keys. Here is a post on it. 1st-gen-dakota/175855-cheep-lift-post1417241.html#post1417241
You can get blocks just about any parts stores. Sizes are available from 1 inch - 6 inches.
You can get Shorter rear spring shackles.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen-...ut-blocks.html https://dodgeforum.com/forum/1st-gen-...le-hanger.html
If you got a V6 you can get V8 torsion bars to give you an extra inch or so.
Add a leaf too.
http://www.jcwhitney.com/autoparts/Product/tf-VehicleBrowse/s-10101/Pr-p_Product.CATENTRY_ID:2005974/p-2005974/N-111+1993+200728540+600003409/c-10101
You can get air shocks too. These are not air bags. So you don't need an on-board compressor. http://www.partsamerica.com/ProductD...50&PTSet=A
Or
https://www.shockshopusa.com/thankyou.html
Universal air bags. https://airbagit.com/index.php?osCsi...beeed6ca3c2580
4wd
Body kit 2in.
Add a leaf too.
Or
