Where to buy
Old Aug 4, 2009 | 06:25 PM
stymie222's Avatar
stymie222
Default Where to buy
If I narrow my charging problem down to the voltage regulator, where is the best place to buy a new PCM module ?
Is this replacement a good idea for the do it yourself person ? Im an electrician and have done a lot of repairs myself.
Check Engine light goes on and off, battery will not charge completely, volt meter is working and indicates charging.
Old Aug 4, 2009 | 06:39 PM
95_318SLT's Avatar
95_318SLT
Year and engine?
The pcm takes about 5 min to change. Just disconnect the battery, unbolt the 60 pin connector, unbolt the computer, bolt in the new computer and bolt in the connector.
Old Aug 4, 2009 | 09:00 PM
stymie222's Avatar
stymie222
Default Module
Thanks for the reply
1992 Dakota ext. cab 3.9 liter V6 Magnum, Air cond
Don't know if this is a part places like NAPA would carry
Old Aug 5, 2009 | 08:32 AM
pashadowops's Avatar
pashadowops
Looks like Napaonline.com has them, otherwise your other choices are dealer or salvage yard. Advance Auto appears to only carry the performance ignition modules.
Old Aug 5, 2009 | 11:01 AM
stymie222's Avatar
stymie222
Default Thanks
Thanks for your help. This baby has over 200K miles
I just double checked the trouble codes. I have 2.
41- generator field not switching properly. I will replace ASD switch. Is this a good indicator of an alternator problem also ?
32- Probably need new EGR valve
Old Aug 5, 2009 | 11:49 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya most likly just replace the alt. And replace EGR. But check all hoses and wires first.
