Afternoon Project
Old Aug 26, 2009 | 08:06 PM
'95Dakota's Avatar
'95Dakota
Default Afternoon Project
I got bored and decided to do something. I wanted new rims but i made the stock ones look pretty sick if you ask me.
Before:
Primed/taped:
After:
Fronts doen, rears tmrrw:
I sanded them down with a sanding drmel type thing in a drill to etch them up. Then i took some good 'ol duct tape and taped them off. Put down about 4 coats of primer, then about 5 coats of paint. Then i went over them for a few mins with a torch to sorta bake it on. Turned out alot better then i had expected.
Comments welcome!
Old Aug 26, 2009 | 08:31 PM
skyshark186's Avatar
skyshark186
Looks good from a distance. Whatever you used to cut them left some decent scaring that you can see in the paint.
I definitely like the way it looks in the last picture though.
Old Aug 26, 2009 | 08:43 PM
'95Dakota's Avatar
'95Dakota
yea, i know. I used a grinder wheel type thing to get the paint off for the first one. The second one doesnt look like that at all, its smooth.
Old Aug 26, 2009 | 10:03 PM
skyshark186
Yeah. First of anything is always a learning curve.
Old Aug 26, 2009 | 10:14 PM
95_318SLT's Avatar
95_318SLT
Yeah, take it from someone who has worked in a body shop... never lay paint over anything thats heavier than 320 grit scratches. And even that rule has its limitations. Should look good when your done though.
Old Aug 26, 2009 | 11:11 PM
'95Dakota's Avatar
'95Dakota
yea. I learned that the hard way lol. But you cant notice it unless your up close.
For the second one i just used the sanding wheel, not the grinder wheel and it came out much better.
I'll post more pics when its all done. Pretty stoked on my good idea
Old Aug 27, 2009 | 10:40 AM
94 mark3's Avatar
94 mark3
you need to paint your center caps to match.
looks good though
Old Aug 27, 2009 | 08:12 PM
'95Dakota's Avatar
'95Dakota
looks good though
Im gunna buy a plastic paint like Krylon for them.
Old Aug 27, 2009 | 08:16 PM
95_318SLT's Avatar
95_318SLT
When you prep the center caps, go buy a grey scotch-brite pad from a home improvement store or an autoparts store in the paint section and scuff them wet with a non waxy car wash soap and water. Then clean them very thoroughly with a paint prep spray you can get at any autoparts store and don't touch them afterwards. Then spray on 2 to 3 light coats.
Old Aug 27, 2009 | 08:37 PM
94 mark3's Avatar
94 mark3
i painted mine semigloss high temp. just because i had it laying around.
but definitely use soap/water with GREY scotch bright pad
