anyone ever swap to a diesel?
Old Sep 14, 2009 | 06:06 PM
Blue 12's Avatar
Blue 12
Default anyone ever swap to a diesel?
Just wondering if anyone has ever seen a cummins swap? Im thinking about trying to find a wrecked 1 ton, and get the motor, trans, transfer case, axles ect.... i want to do this to my truck or a YJ....
Old Sep 15, 2009 | 10:51 AM
dakota33's Avatar
dakota33
If you do find one.. do it to the dakota haha.
I actually seen in a forum before where they did swap a deisel.. so it does work, obviously you can make anything work.. But it would be alot of customization. I wish I could find that truck again that had it..
Old Sep 15, 2009 | 04:06 PM
Crazy4x4RT's Avatar
Crazy4x4RT
That would be sweet. And if anyone has the room for one you do. Just a ton of modification.
Old Sep 15, 2009 | 08:13 PM
Blue 12's Avatar
Blue 12
i would need to buy something to get to work with while i was doing something like that to my dak. and then, im not sure if the frame could take it. a lot of areas are pretty thin(lots of rust before i got it coated). i would need to plate the entire frame, but that would probly be true for a jeep aswell.
the CTD straight 6 would be longer than the magnum v8, so the firewall may need to be moved back. anyone know how long a 4.0 jeep motor is? they are a straight 6 too...
Old Sep 15, 2009 | 08:42 PM
festerw's Avatar
festerw
The 6BT Cummins IIRC is around 37 inches. A 4BT may be an easier swap.
Old Sep 15, 2009 | 08:53 PM
Blue 12's Avatar
Blue 12
thx, if i do this, im going all out. ill be adding the usual power adders to the 5.9 aswell, the little one isnt going to cut it i want to be able to smoke at least 3 tires at once oh and tow ANYTHING
Old Sep 15, 2009 | 09:44 PM
Hahns5.2's Avatar
Hahns5.2
Hope you don't drive that thing on the street...
A 4BT would be a lot more practical. Want to tow "anything"? Get a full size!
Old Sep 15, 2009 | 10:08 PM
Blue 12's Avatar
Blue 12
my dak is my daily driver.... i own it and my race bike
im not practical... note the tires
i would rather build something than buy it
Old Sep 16, 2009 | 02:02 AM
skyshark186's Avatar
skyshark186
I watched a guy put a 7.3 turbo in a 63 scout. So to answer your question. Yes....it can be done. There are very few 4x4s with a smaller engine bay than those scouts.
I would be too lazy. New engine, transmission, transfer case, fuel tank, fuel lines, motor mounts, transmission crossmembers, driveshafts, springs up front to handle the weight and springs in rear to handle the load. Sigh.....Im getting sleepy just thinking about it. And youd probably want for sure a front axle and probably a rear too. So....basically youd keep the body and the frame, and your frame sounds like its seen better days so........... .
Yup.
Old Sep 16, 2009 | 05:06 PM
22dodge's Avatar
22dodge
Here's what you do. Get a cummins 4BT out of like a bread truck. get the motor plate adapter from a 6BT gen1 cummins and bolt it in. it will work some fabrication for engine mounts, wiring, exhaust. My friend used a 4bt in a 4x4 full size blazer and it was surprisingly stout for towing. empty he was pulling 28mpg all day.
