spedometer
Old Oct 8, 2009 | 09:07 PM
dakota33's Avatar
dakota33
Default spedometer
ok.. Im having a issue, my donor truck is a 92, the truck this motor is going in is a 95. The person switching it over says the 92 has cable for the spedometer, and the 95 is electronic so I wont be able to have my spedometer working... anyone know what I can do to solve this problem.. good detail would be great!
Old Oct 8, 2009 | 09:13 PM
skyshark186's Avatar
skyshark186
You should be able to switch out the unit in the transfer case. Its a 10 second job.
Old Oct 8, 2009 | 10:08 PM
dakota33's Avatar
dakota33
oh.. well i was told this by the person doing it.. does anyone know of any instructions.. or pics on what has to be done. and it is in the transfer case you say? is it easy to do while the transfer case is on the truck?
Old Oct 8, 2009 | 10:10 PM
dakota33's Avatar
dakota33
wait, it cant be the transfer case? because im keeping my transfer case.. and he showed me the wires that need to be hooked up with were on my old motor or transmission.. im not sure what it comes off?
Old Oct 8, 2009 | 11:21 PM
skyshark186
No its on the transfer case trust me. Its on the drivers side half of the extension cone. About half way up. The ones on the 93s are part mechanical part electrical. Im pretty sure the earlier ones were just mechanical. Either way, its all the same.
I dont have that stuff on my truck anymore, or Id go take a pic. The only 231 I have is destroyed and half trashed, or on its way to 318.
This is not a good picture, but it will work.
See the big black and white thing sticking out of the side of the extension cone? Thats the speed sensor. Yours is in the same place. Its held in by one bolt, and a wierd looking split armed bracket. You pull the bolt, the bracket falls off, and you pull lightly on the spensor and it comes out.
Old Oct 8, 2009 | 11:52 PM
95_318SLT's Avatar
95_318SLT
Skyshark is right... the speed sensor is in the transfer case. I know, I just took two of them apart! Just a thought, if the speed sensor is in the transmission, then its a 2wd transmission and you need to keep looking!!!! Unless the wires he pointed out were for the park/neutral safety switch.
Old Oct 9, 2009 | 12:14 AM
Coadster's Avatar
Coadster
Get a GPS that displays your speed!
Old Oct 10, 2009 | 10:37 AM
dakota33's Avatar
dakota33
ok.. so im using my own transfer case but is told it still wont work.. because there is still a plug in/sensor or something off the motor that I have no place for in my trasfer case causing it to not work.. i think gps is going to be the way to go lol
Old Oct 10, 2009 | 12:16 PM
95_318SLT's Avatar
95_318SLT
There are only 2 plugs on a t case... speed sensor and 4x4 indicator light. There is no reason your t case won't work if it worked before.
Old Oct 22, 2009 | 11:11 AM
dakota33's Avatar
dakota33
GPS may be the way to go... anyone know of any links.. cheapest ones possible? all I need is one to track my speed nothing else.. tache on it would be cool lol
