No Spark
Old Oct 19, 2009 | 06:36 PM
Dodge 94's Avatar
Dodge 94
Default No Spark
I've got no spark in number one from the distributor to the spark plug.
I've changed the cap, rotor, distributor and coil. Still no results. Anybody got any ideas what it could be?
Old Oct 19, 2009 | 07:31 PM
woodbutcher5691's Avatar
woodbutcher5691
bad wire or plug maybe??
Old Oct 19, 2009 | 09:02 PM
95_318SLT's Avatar
95_318SLT
The is an off-the-wall answer, but if this was a problem before you replaced all the ignition components, and now it still is after they are new, you could be getting no reading by the crankshaft position sensor at cyl 1.
But I would suggest you download the '95 FSM, the link is in FAQ2 (its a rapidshare link). That manual would have troubleshooting guidelines, cause it's very hard for one of us to determine an electrical problem without the truck in front of us.
Old Oct 19, 2009 | 10:37 PM
Dodge 94's Avatar
Dodge 94
Thank you both for your replies. I'll definitely download the FSM and see what it says.
Old Oct 20, 2009 | 01:52 AM
pioneerbirdy's Avatar
pioneerbirdy
I bet 10 bucks its the crank sensor.
if check engine light is on there is a trick to get a code from the computer.
with out starting it. Turn key to accessory then back then to acc then back then acc and leave it there and see if you get a code. It will be a 2 digit number.
It should go, flash flash flash(how many times the first number is) then it will pause then the next number will flash.
first code might be start of test - 88
no code or end of code - 55
crank sensor - 24
example once key has been turned to get code you might see code 88 and or 55 meaning no code
if you get 88,24,55 or 24,55 means crank sensor then end of codes.
if it like my truck i dont get code 88 at all
Old Oct 21, 2009 | 12:36 AM
Dodge 94's Avatar
Dodge 94
Thanks everybody for the information. After finally getting the '95 FSM downloaded (on dial up it took about 4 1/2 hours!), it looks like my next move is replacing the flywheel. We'll see how it goes.
Thanks again.
Old Oct 21, 2009 | 01:35 AM
95_318SLT's Avatar
95_318SLT
Whoa!! Replace the flywheel?!?! Lets talk about this first. What did you read in the manual first of all, and why do you think the flywheel needs replacing? And I assume since you said flywheel and not flexplate, that you have a manual transmission?
Old Oct 21, 2009 | 09:56 PM
pioneerbirdy
if you have to replace the sensor u just need to pick up a special socket.
Old Oct 22, 2009 | 05:13 PM
Dodge 94's Avatar
Dodge 94
I swapped from a 3.9 to a 5.2 and thought that the flywheels were the same for a 6 cyl. as for an 8 cyl. However, looking at the diagram on page 3 of the PDF file 95AN_8D, I see now that the flywheels are different.
Old Oct 22, 2009 | 08:36 PM
woodbutcher5691
That li'l tidbit would have been handy in your first post. Good that you figured it out.
