35" tires
Old Oct 22, 2009 | 12:06 PM
dakota33's Avatar
dakota33
Default 35" tires
Just wondering.. should I do this or not, I got a 1995 dakota 2" body lift, 2" lift blocks, reindexed key for front. I had 33" I want to go 35", I know I will need to cut fenders... would I need to cut way to much, do you think I should do this?.. will the tires maybe look to big for the truck with that low of lift?
Old Oct 22, 2009 | 02:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
35's would be nice. I have enough room for 35's. But up front on articulation angles it may rub. Also it would be good for performance and gas mileage to change your differential gears. You may want to raise your rear a bit. I was always worried about the strength of the front axle with that big of tires, but Blue12 has 38's on stock axles with no problems.
Old Oct 22, 2009 | 03:39 PM
dakota33's Avatar
dakota33
ya, I think im going to go ahead with it, Im going with the MT Baja Claw.. Ya, I know up front is going to be pretty close, so thats why I need to cut more off fenders.. but going to make it clean. What do you mean raise the rear.. the rear is already higher then the front, because has body lift, and lift blocks.. so rear is fine. Im not worrying about the axles cause Im not going hardcore on this,, wont see off road often.
Old Oct 23, 2009 | 10:25 AM
Crazy4x4RT's Avatar
Crazy4x4RT
If you do post up plenty of pics. If you could do some articulation shots so I will know if it rubs.
Old Oct 23, 2009 | 11:22 AM
dakota33's Avatar
dakota33
Ya, I will for sure!.. cant say its going to be right away.. pricing them at a few different places., local shop here wants around 2k for all four, does anyone know of where to get these as cheap as possible? keep in mind im in Canada and will need somewhwhere that can ship here cheap!
Old Oct 23, 2009 | 11:57 AM
skyshark186's Avatar
skyshark186
is that 2k canadian or american? Thats a ton of money. Ive never paid more than 500 for a set of tires. Im a cheap a$$ and only buy used, but I just cant justify spending that kinda money on tires. Especially not when you can haunt craigslist or the canadian equivalent and buy them with 75% or better tread for cheap.
Old Oct 23, 2009 | 12:02 PM
dakota33's Avatar
dakota33
2k Canadian, ya its alot!, I really dont wanna spend that much, but I want those specific tires.. dont wanna settle for anything else. so anyone at all know of a good canadian site maybe?
Old Oct 24, 2009 | 12:44 AM
'95Dakota's Avatar
'95Dakota
2 G's? really? Those tires here are like 270 a piece.
Old Oct 24, 2009 | 08:07 PM
dakota33's Avatar
dakota33
serious... where?, says ur from Canada.. where abouts?
