Slave Cylinder?
Old Oct 26, 2009 | 09:02 PM
'95Dakota's Avatar
'95Dakota
Its noticeably harder to where i dont notice it when its warm, and i have to put quite a bit more pressure to put it in.
i've tried to see if lower revs or higher revs fix the problem and if i keep the revs low to get the clucth out, 90% of them time it doesnt do it.
Old Oct 26, 2009 | 09:17 PM
95_318SLT's Avatar
95_318SLT
I think the only way to find out whats wrong at this point is to pull the transmission. Either the hydraulics are starting to go or the other thing I thought of today is that the fingers on the pressure plate are loosing their integrity.
Old Oct 26, 2009 | 10:20 PM
'95Dakota's Avatar
'95Dakota
well since it is a '95, and it probly hasnt been done yet, i wanna get a new clutch put in it. I dont know how soon that will be since i dont have a job yet.
I havent noticed it as much as i did before. I think maybe the clutch has worn down some? and not caused hot spots? I'm not sure.
Old Oct 27, 2009 | 12:39 AM
94 mark3's Avatar
94 mark3
My truck isn't a 5spd but is there an adjustment o. The master cyl or the pedal inside the truck? Sounds like it's out of adjustment a little bit
Old Oct 27, 2009 | 12:47 AM
95_318SLT's Avatar
95_318SLT
Nope, not adjustable.
Old Oct 27, 2009 | 12:56 AM
94 mark3's Avatar
94 mark3
I find it very odd there isn't. I've never see. A clutch setup that isn't adjustable in some way
Old Oct 27, 2009 | 12:58 AM
95_318SLT's Avatar
95_318SLT
Most modern hydraulic clutches aren't adjustable. The old cable clutches were because the cables were known to stretch over time. With these trucks, you can't even properly bleed the slave cylinder. It's all a sealed unit that comes preassembled and bled.
Old Oct 27, 2009 | 01:03 AM
94 mark3's Avatar
94 mark3
I would say start off replacing slave cyl since it's cheapest. And see what happens next
Old Oct 27, 2009 | 01:05 AM
94 mark3's Avatar
94 mark3
My 300zx has 2 bleeder Valves and a pedal Adjustment
Old Oct 27, 2009 | 01:11 AM
95_318SLT's Avatar
95_318SLT
Lol, sadly, you can't replace just the slave cylinder. Like I said, the entire hydraulic assembly comes as a sealed, assembled unit with fluid and pre-bled.
Here is a picture of the master cyl/pedal. There is only one mounting point on the pedal arm and nothing to adjust.
DSCN0148.jpg?t=1256620685
