Slave Cylinder?
Old Oct 27, 2009 | 09:16 PM
  #31
skyshark186's Avatar
skyshark186
advance auto's website shows them available as 2 different pieces. The master being 135 bucks and the slave 75.
Old Oct 27, 2009 | 09:29 PM
  #32
94 mark3's Avatar
94 mark3
Maybe a company decided to make a 3peice aftermarket set.
Old Oct 27, 2009 | 09:31 PM
  #33
95_318SLT's Avatar
95_318SLT
You may want to make sure of what you're getting. I saw that too, and I didn't want to post it up because the factory slave cylinder has no bleed valve. If that one does have a bleed valve, then go for it and let me know how it worked out!
Old Oct 28, 2009 | 08:30 PM
  #34
'95Dakota's Avatar
'95Dakota
im not suire what one it is. I was in a bit of a hurry so i didnt really take a good look. I'll try to find a repair manual or something and get a link to what she showed me
Old Jan 23, 2016 | 06:55 PM
  #35
KevinSandidge's Avatar
KevinSandidge
i'm googling 'riding the clutch'
Last edited by KevinSandidge; Jan 23, 2016 at 09:58 PM. Reason: couldn't find the delete button
Old Jan 23, 2016 | 07:34 PM
  #36
RalphP's Avatar
RalphP
Keeping the foot on the clutch pedal, which keeps the clutch partially "disengaged" or at least keeps the throwout bearing engaged onto the clutch fingers instead of coming clear.
It's the equivalent of riding the brake pedal enough to drag the brakes.
RwP
Old Jan 23, 2016 | 10:04 PM
  #37
KevinSandidge
thanks ralph; just seeing your reply. when i come to a light thats on a hill, i have been partially pressing down on the clutch and giving enough gas to keep the truck still and ready for take off.....i see now that is not good either :/
Old Jan 24, 2016 | 09:46 AM
  #38
RalphP's Avatar
RalphP
No, it's not.
It will wear out the clutch a LOT quicker if you do.
RwP
Old Jan 28, 2016 | 03:26 AM
  #39
Thomas_kota's Avatar
Thomas_kota
Originally Posted by 95_318SLT
Well, now I'm wondering if something is leaking onto the clutch disc... like oil or transmission fluid. The problem with that is that it still bugs me that you said it got hard to put in gear. That means the clutch isn't 100% disengaged which makes me think it's still a hydraulic issue. Unless the clutch plate is sticking to either the flywheel or pressure plate.
Thats an good point. If you have a bad enough oil leak it might cause that. I know with brakes oil or brake fluid on the friction material will soften the friction material and make it super super grabby.
Its really hard to say for sure though...
