bent...uh?...WTF
Old 11-14-2009, 04:05 PM
burntricer's Avatar
burntricer
burntricer is offline
Default bent...uh?...WTF
hey
i got a 96 dakota 4x4, 318, 4 spd, chry 8.25/3.55 gears
ANYWAY
my RIGHT REAR tire is wobbeling...
i cannot feel ANY vibration.
here is what i have troubleshooted so far
BRAND NEW TIRES!!!!!! so its not cord seperation
rotated tires, still does it ----> not a bent rim
pulled tire -----> still does it (on jackstands, visable at the brake drum)
removed brake drum ----> Still does it
CHANGED AXLE (.060 runout on old, <0.002 runout on new) ----> STILL ****ING DOES IT
checked wheel bearing -----> STILL DOES IT
anyone have any clue what else it could be?
Old 11-14-2009, 05:53 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Did you get the tires ballanced?
Old 11-14-2009, 09:07 PM
skyshark186's Avatar
skyshark186
skyshark186 is offline
You say you changed the axle. Did you change the drum? Could be a badly warped drum. Is it visible at the axle with the drum off?
Old 11-15-2009, 07:10 AM
grswat's Avatar
grswat
grswat is offline
The simplest thing I can think of is the wheel stud threads being buggered up so the lug nuts aren't actually tightening up the wheel just on the studs. Thats my thought.
Old 11-15-2009, 01:31 PM
burntricer's Avatar
burntricer
tire is balanced.
It WAS visable with the drum off.
i havent checked since i changed the axle but i will
and the rim is good. the holes are not oblonged, aswell is the threads on the lug studs
Old 11-15-2009, 01:58 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Check out the 95 service manual we have in the FAQ. Go to section 22. It give a complete diagnostic of vibrations. A nice chart on speed of vibrations.
Quick Reply: bent...uh?...WTF
