95 dak 3.9 auto 4wd 1st gear whine, 34k miles
Old Nov 20, 2009 | 04:14 PM
drussell4801's Avatar
drussell4801
Default 95 dak 3.9 auto 4wd 1st gear whine, 34k miles
I have a 1995 auto 4wd dak, with only 34k miles. Is it normal to have a whine in first gear?
and yes, in case you're questioning it, I do have only 34,000 miles on it. There is absolutely no whine in any other gear. I should say that the whine isn't really loud. I only hear it if I'm driving without the blower or radio on. Its almost like the same kind of whine you hear when in reverse in a manual trans vehicle, except much quieter.
I had a trans flush done when I got it about 3000 miles ago(full flush, not just drain and refill). The new fluid is the BG fully synthetic trans fluid.
It has not been used for towing, and I bought it from my grandfather, who drove it like a grandfather..
Old Nov 20, 2009 | 05:11 PM
95_318SLT's Avatar
95_318SLT
Was this BG fully synthetic trans fluid ATF+4? Cause these transmissions aren't to be ran on anything but ATF+4.
Straight from allpar.com:
The Center for Quality Assurance, which Chrysler uses to run its ATF+4 licensing program, wrote: “The previous MOPAR ATF+3® formulation was discontinued in 2005 and ATF+4® is recommended for all transmissions filled with ATF+3®.”
Several companies now sell "universal" fluids. If they state that they are compatible with ATF+4®, they may work well, especially for those unsure of which fluid to use. The Center for Quality Assurance warned us to check the label for Chrysler’s license number, and to make sure the fluid is on their list of ATF+4® licensed and tested fluids.
Here is that list of licensed and tested fluids:
Advance Auto Parts ATF+4®
Carquest ATF+4®
Castrol ATF+4®
Chevron ATF+4®
Citgo Transgard ATF+4®
Coastal ATF+4®
Conklin ATF-Xtra Plus ATF+4®
Formula Shell ATF+4®
Great Wall ATF+4®
Havoline ATF+4®
MAG 1 ATF+4® Mobil ATF+4®
Mobil Super ATF+4®
Mopar ATF+4®
MotoMaster ATF+4®
NAPA ATF+4®
Northland ATF+4®
O’Reilly ATF+4®
Parts Master ATF+4®
Parts Plus ATF+4®
Pennzoil ATF+4®
Petro-Canada ATF+4®
Quaker State ATF+4®
Ravenol ATF+4®
Sinopec ATF+4®
Super Tech ATF+4®
Texamatic DC ATF+4®
Ultramax ATF+4®
Valvoline ATF+4®
Old Nov 20, 2009 | 10:33 PM
drussell4801
according to this it 'meets or exceeds the performance requirements' of ATF+4
http://www.bgprod.com/products/transmission.html
here is a product listing on bg's site
http://www.bglsi.com/ATF.PDF
but i'm still wondering if a compatibility issue could cause just the one small symptom of first gear whining.. it shifts fine..
Old Nov 20, 2009 | 10:59 PM
95_318SLT's Avatar
95_318SLT
After reading that, it's hard to say if it's the fluid, but knowing how finiky the dodge automatic transmissions are, I'd be hesitant to use anything labled "universal". Maybe someone else will have better input.
Old Nov 24, 2009 | 12:19 AM
drussell4801
i was hoping someone might have some personal experience using this fluid. I agree that a universal fluid doesn't sound like the best idea, but I got the fluid for free. I traded my carbon fiber motorcycle helmet(after i sold my bike) to a friend who is a technician for a trans flush and $50. He swore it was the best fluid ever; cue the gullibility..
The part that is confusing is: how can it have everything a dex/merc trans needs along with everything an atf+4 trans needs along with everything a honda trans needs???... without any problems??? Is it just part atf+4, part dex/merc, and part honda atf?
I think I'm gonna shoot an email to BG to get clarification on the product.
I'll post my email and their response(assuming I get one).
btw, 95 318slt, thanks for the help. You've been there every time I've had questions on here.
Old Dec 5, 2009 | 10:35 PM
drussell4801
I've looked and looked.. There is no phone number to call for BG. On their website it says to direct questions to their distributors. bleh
Old Dec 6, 2009 | 03:56 AM
mazda7475's Avatar
mazda7475
you want someone who has experience with tranny fluid you came to the fight place. i changed mine every 6 months for 8 years. my 89 dipstick says dexron II only and my tranny is basically the same as the later models that take atf+3 only.
I've used every fluid known to man and found the best (in a tranny that slips) is the wal-mart full synthetic. they stopped selling it here so i went to the semi-synthetic.
whatever you do do not use a high mileage tranny fluid, i put in valvoline high mileage and darn near blew it out in 2 weeks. the castrol atf+4 was also good but not the best and it was expensive. if you want something good and cheap stick to the wal-mart synthetics, its the only one i know of that is actually compatible with any tranny.
