2002 4.7 NV3500 on a 5.2?
Old Dec 2, 2009 | 04:11 PM
grswat's Avatar
grswat
Default 2002 4.7 NV3500 on a 5.2?
Hey all. Will a 2002 Dakota 4.7 NV3500 work with my 96 5.2? Thanks.
Old Dec 2, 2009 | 04:59 PM
skyshark186's Avatar
skyshark186
Think the bolt pattern may have changed. Someone will chime in for sure though.
Old Dec 2, 2009 | 05:15 PM
dbilik's Avatar
dbilik
I think the bolt patterns are the same. Should work. THe only reason I say this is because I researched putting my NV4500 onto my 2001 QC with the 4.7. If you give me until Thursday night I can check, I have an NV3500 and a 45RFE sitting in my garage right now.
Old Dec 2, 2009 | 07:56 PM
grswat's Avatar
grswat
That'd be sweet. Found a craigslist one for $400 57k miles. If I ever gather everything I'm going to do a step by step auto to manual swap and post everything with pictures etc...
Old Dec 2, 2009 | 09:16 PM
Crazy4x4RT's Avatar
Crazy4x4RT
From what I read on the 2nd Gen. Dakota sub forum is that the bell housing bolt pattern is different.
And we do got a post on how to do an auto to a manual swap, with tons of pics. But feel free to do one. The more the better. Here it is, it is located in the FAQ2 in this section. https://dodgeforum.com/forum/1st-gen...-5-2l-4x4.html
Old Dec 3, 2009 | 05:56 AM
grswat's Avatar
grswat
I'm thinking they are different from everything I have found. I've read through that swap. I'm gonna try the junkyards again on Monday but I haven't had any luck previously.
Old Dec 3, 2009 | 06:12 AM
grswat's Avatar
grswat
How about a Ram transmission? I think they have the shifter in the tailshaft but is it movable or adaptable?
Old Dec 3, 2009 | 10:01 AM
skyshark186
Ram transmissions are the same.
Old Dec 4, 2009 | 04:52 PM
dbilik's Avatar
dbilik
The bolt patterns are different. I checked last night. A lot more bolts on the NV3500. And now that I think about it I should have known this right away, it is because the 4.7L uses a structural plate at the bottom of the trans/engine joining, which adds a lot of rigidity to the unit and must let them get away with fewer bolts on the top.
Old Dec 5, 2009 | 07:37 AM
grswat's Avatar
grswat
I figured there was a bolt difference. Off to the junkyard monday morning to search. Anyone in the Columbus, OH area wanna go yardin?
