fuse problem???
Old Dec 13, 2009 | 11:41 PM
96_dakota's Avatar
96_dakota
Default fuse problem???
ok so i start up the truck today and everything is fine. but tonight after i turn on the lights the dash lights go out and the gauges dont work (rpm, speedo) the blinkers just stay lit. any help would be apprecated.
Old Dec 13, 2009 | 11:55 PM
95_318SLT's Avatar
95_318SLT
Could be a fuse issue or a ground wire issue. No way of knowing for sure except to start testing wires and connections.
Old Dec 14, 2009 | 09:19 AM
pashadowops's Avatar
pashadowops
When my truck starts doing these same exact things, I know it's time to replace the headlight switch. Since I am revamping my interior, the plastic panel below the steering wheel is off so I can wrap the panel that holds the OD switch and the headlight ****. That usually rattles things back into place and everything works fine again. I know it sounds stupid and absurd but, it works. As soon as I put in my relays and replace the headlight switch, I shouldn't have that problem anymore. If by chance the gauge lights don't come back on you may have to remove the gauge panel and clean the contacts on the lighting circuit board and then put a little dielectric grease on it so it doesn't get oxidized again.
Old Dec 15, 2009 | 10:11 PM
96_dakota's Avatar
96_dakota
weird, but that was my problem. the wiring rattled loose on the ****. cleaned the connection and rewired it. Thanks for the Help guys!!
Old Dec 16, 2009 | 08:15 PM
Gummer's Avatar
Gummer
I know my truck had the same issues. I have replaced feet of rotten wire under the hood as well as the headlight switch.
