ok tranny pan replacement
Old Dec 22, 2009 | 05:05 PM
Wishihadahonda's Avatar
Wishihadahonda
Default ok tranny pan replacement
i did the gasket on the trans pan and the filter and im bout to fill her up.. how many quarts should i put in to start with? i dont want to over fill but i dont want to run it too low then check it u know
Old Dec 22, 2009 | 07:03 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I'v always done 6. Then check.
Old Dec 22, 2009 | 09:38 PM
Wishihadahonda
i did 4 and i havent checked it yet 4 is what auto zone said and that is all i had bought lol i havent drove it anyway just started it and let it run for a min i got a mean lifter tap and its smoking pretty good. not sure why it has been sitting for 5 months or so and it needs a oil change so im hoping that is what it is
Old Dec 23, 2009 | 02:14 PM
mazda7475's Avatar
mazda7475
heres a tip guys. if your going to remove the pan for any reason, disconnect the upper line from the rad. put a hose over it and run that into a pan that holds just over 4 liters (4 quarts). start the truck and put it in neutral for about a minute until all the fluid is pumped out. shut it off, replace the line then remove your tranny pan. you don't have to deal with a pan full of fluid especially if your working in the yard. just make sure you don't keep running the engine after all the fluid is out.
Old Dec 23, 2009 | 02:21 PM
Crazy4x4RT's Avatar
Crazy4x4RT
That is a good tip Mazda, but I wouldn't dare it. Just get $7 for a transmission drain plug. easy to install. Takes all the mess out of it. That is what I did. And to replace the fluid in the lines, just disconnect it and run a air hose to it, to flush out all the dirty fluid in the line.
http://www.autozone.com/autozone/cat...brandName=Help
Old Dec 23, 2009 | 03:26 PM
mazda7475's Avatar
mazda7475
doesn't hurt it crazy. did at least once a year for 7 years and never had a problem. i did it that way to replace all 12 liters. disconnect, drain fill, disconnect, drain fill, etc.
i did switch to a $5 walmart hand pump that went down the filler tube the last few times.
did not know you could by a drain plug for it. can you use that plug to replace the plastic one in the differential?
Old Dec 23, 2009 | 03:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes you can use it on the diff. But to replace it you probably will have to weld in plug to cover the large hole. But the diff cover plug is also the fill in. And the fluid lever marker. I would say just leave it.
Old Dec 23, 2009 | 07:29 PM
Wishihadahonda
alright so i tried driving it with the 4 quarts originally and it was slippin bad! so i drove to the local autozone which is right around the corner and bought 2 more and put them in i havent checked it yet but its driving fine i havent really got it warm yet. i shouldnt have any issues
Old Dec 24, 2009 | 01:15 AM
dodgerules86's Avatar
dodgerules86
Yea... so you really need to check that fluid level.
Unless, you know, you want to burn up clutches and replace a transmission because you didn't check fluid level... not my $$!
Old Dec 25, 2009 | 01:53 AM
Wishihadahonda
i wasnt driving it without checking it just to the autozone and back but its so cold here that 2 min drive didnt get it warm i checked it today drove it to get the oil changed and it got warm checked it and it was all good not low at all. found one loose bolt in the pan im gonna keep my eye on it and make sure they dont vibrate out. might pull em out one by one and locktite them
