Wheel/Rim combo info requested
Jan 3, 2010 | 08:18 PM
Found a set of 15x?? 2000 Dodge Durango set of rims, with 31x10.5R15 BFG T/A's on them
I have a completely stock 1995 Dakota 3.9L 4x4
What do I need to do to fit them?
Jan 3, 2010 | 09:10 PM
Probably 15x8's, crank the torsion bars and they should fit maybe with a slight rub.
They look like these
[IMG]
[/IMG]
Jan 3, 2010 | 09:18 PM
exactly like those.... what size tires are those?
Jan 3, 2010 | 09:24 PM
31x10.5x15's though they may actually be slightly larger since they're retreads.
Jan 3, 2010 | 09:28 PM
hmm... what do I need to do to put a small lift on the truck?
I'm a HUGE European car guy, and dont work on trucks very much. How do you "crank" the torsion bars, and raise the rear a little bit?
Jan 3, 2010 | 10:13 PM
i didnt have to do anything to put the 31x10.5's on, only leveled the truck
i have 32x11.50-15's on it now and have really no issues on rubbing
Jan 3, 2010 | 10:14 PM
Quote:
Originally Posted by
89gt308
this makes me REALLY happy
Jan 3, 2010 | 10:15 PM
follow the torsion bars to under the cab and they are adjustable there.
Jan 3, 2010 | 10:21 PM
what about the rear? any way to raise it slightly?
Jan 3, 2010 | 10:46 PM
Yes cranking the torsion bars up a bit will give you more clearance. The rears from factory are already set higher than the fronts. So they will be fine. But if you want more lift you can add lift blocks. For TONS of more lift Ideas check the FAQ2.
