please help
Old Jan 7, 2010 | 11:31 PM
dakota26's Avatar
dakota26
no enging not over heating runing right in the middle
Old Jan 8, 2010 | 02:26 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by dbilik
How do you know you have no pressure? If you have been driving the truck for a while after a water pump change without pressure you should be having problems that indicate no pressure. Maybe Crazy can tell me if I am wrong, but the pump doesn't build up the pressure, the change in temperature does, the pump just circulates the coolant.
Yes correct!
The cap may not be hot to the touch on a fully functioning system.
Old Jan 9, 2010 | 05:46 PM
mazda7475's Avatar
mazda7475
low coolant level?
Old Jan 9, 2010 | 09:33 PM
dk sport's Avatar
dk sport
you cant have both on psi and no leak if temp is running at half gauge scienct you have heat psi will build if its not then YOU HAVE A LEAK you need a psi tester. the psi is going some wear tester shoild also test caps if thear is an auto zone near you they rent them
Old Jan 10, 2010 | 07:51 AM
dakota26's Avatar
dakota26
i think it is my heaer core i get heat when driving nice and hot but when i stop its warm can this be even tho i have clean water coming out both in and out let of the heater core ??
Old Jan 10, 2010 | 09:07 AM
dk sport's Avatar
dk sport
ther can still be hard deposits in the core that the flush isent strong enough to desolve but thats a flow problem this would not stop presur from building
Old Jan 10, 2010 | 03:30 PM
dakota26's Avatar
dakota26
wher do u think the flow problem is then raditor ?
Old Jan 10, 2010 | 06:06 PM
festerw's Avatar
festerw
Are you positive that it's leaking? Usually they will overheat if not under pressure.,
Old Jan 11, 2010 | 09:15 PM
dakota26's Avatar
dakota26
no leaking anywher my heat is good when driving but not when stoped the pressure is good was tested by a mec good shop around home the cap was tested too im still gussing heater core i might be wrong but only thing i can guess
