radiator cap brand new not building pressure thermostat is new 195 heater core has been flushed nothing coming out clean water new water pump any other suggestions on why no pressure in radiator
How do you know you have no pressure? If you have been driving the truck for a while after a water pump change without pressure you should be having problems that indicate no pressure. Maybe Crazy can tell me if I am wrong, but the pump doesn't build up the pressure, the change in temperature does, the pump just circulates the coolant.
