My 1993 V8 Dakota
Old Jan 20, 2010 | 02:37 PM
mmanahan1's Avatar
mmanahan1
Default My 1993 V8 Dakota
sometimes after drivin it stalls. any ideas
Old Jan 20, 2010 | 03:16 PM
wewanaplay's Avatar
wewanaplay
stop driving, it'll quit stalling
Old Jan 20, 2010 | 03:21 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this into the 1st Generation Dakota Sub-Forum. When It stalls, is it Idle? If so it may be the IAC.
Old Jan 20, 2010 | 03:32 PM
95_318SLT's Avatar
95_318SLT
We really need more info than that. It could be a bad IAC, MAPS, TPS, ECTS, o2S, a vacuum leak, a power problem. Sorry, can't narrow it down based on your description of the problem!
Old Jan 20, 2010 | 07:46 PM
mmanahan1's Avatar
mmanahan1
sryy for the lack of info. the stalling mostley accurs right after i start it up. it revs up and gradualy dies down, sometimes it will happen when i put it in gear.
Old Jan 20, 2010 | 10:02 PM
95_318SLT's Avatar
95_318SLT
Sounds like the IAC (idle air controller). This is located at the back of the throttle body and is held in by 2 torx screws. It is a motor driven valve that controls airflow when the butterflies are closed and they are notorious for freezing up. Basically, if it freezes up while barely open, it chokes the engine at idle.
Old Jan 20, 2010 | 10:49 PM
mmanahan1's Avatar
mmanahan1
would it be easy to replace, and would i need to get a gasket for it
Old Jan 21, 2010 | 12:22 AM
95_318SLT's Avatar
95_318SLT
Very easy, like I said there are only 2 torx screws holding it in. Unplug it, unbolt it, bolt in the new one, plug it in. Done. No gasket.
Old Jan 21, 2010 | 08:32 AM
mmanahan1's Avatar
mmanahan1
is there a way to clean it first, or should i just replace it right away. is there a certin way to put the new IAC in.
Old Jan 21, 2010 | 01:30 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Just buy a new one. It installs only 1 way. Just make sure you put the wire connector on the same side as before.
