95 dak 3.9 2wd
Old Jan 24, 2010 | 01:32 PM
dusterdude's Avatar
dusterdude
Unhappy 95 dak 3.9 2wd
whats the big secret to getting at and removing the top motor mount bolt.there is a spoon type piece in the way,i can get my finger on it,but i cant get a wrench or a socket anywhere close.btw,this is on the drivers side,any ideas?thanks
Old Jan 24, 2010 | 01:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The mount probably is bent up. Just try to use pry bars or anything that will help. It happened to me too! If you have to brake that tab.
Old Jan 24, 2010 | 02:02 PM
95_318SLT's Avatar
95_318SLT
A picture might help! I can't picture in my head what you're talking about. I have a '95 2wd 3.9L in the garage that currently looks like this:
DSCN0338.jpg?t=1264359658
... and I don't remember anything being in my way of taking the bolt out of the motor mount.
Have you tried getting under the truck and attacking it from the bottom if you can't get it from the side or top?
Or even better yet, have you removed the inner fender wells to get to it. Removing them gives you room to get to anything around the motor!
Old Jan 24, 2010 | 02:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is a quick pic. The arrow is pointing to the bolt he is talking about. The tab on the side can get in the way. Not to mention the rubber if it is all deformed.
Old Jan 24, 2010 | 02:20 PM
95_318SLT's Avatar
95_318SLT
Oh, ok. I thought he was talking about the bolt that actually holds the motor in, not the mount to the frame. That makes more sense now! I haven't taken those off the frame yet!
Old Jan 24, 2010 | 02:23 PM
Crazy4x4RT's Avatar
Crazy4x4RT
That bolt goes to the motor. The shaft that goes across is the bolt that goes to the frame.
Old Jan 24, 2010 | 03:02 PM
dusterdude's Avatar
dusterdude
crazy,thats it.i see how it should be now.it appears a socket should be able to get under that tab thing.thanks for the pic
Old Jan 24, 2010 | 03:24 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Sure No Problem! Good Luck!
