Changing Thermostat - RTV Sealant
Old Jan 24, 2010 | 01:43 PM
jtdunc's Avatar
jtdunc
Question Changing Thermostat - RTV Sealant
Newbie here guys.
Just inherited a 92 Dak Sport V6. Had been sitting for a year or so.
Changed out the oil and did a complete tune-up.
Got a new thermostat and gasket.
Do I need to use a thin coat of RTV sealant on that "rubber" gasket?
Second question, looks like I have good access to the two bolts onto the block. Can't I just put a drain pan under the engine and unscrew those bolts, scrape the gasket area clean and drop a new stat in?
What direction does it go?
What am I missing?
Old Jan 24, 2010 | 02:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Its best to put a small amount of RTV on the gasket only not the thermostat. Yes you can do the way you described. When removing the housing and the thermostat remember the way it went on. To make it easier you may have to remove the AC compressor.
Old Jan 24, 2010 | 02:09 PM
95_318SLT's Avatar
95_318SLT
There is a special rtv silicone specifically made for thermostats... use that. Don't use too much though, cause if it spreads out into the water passage as you tighten down the neck, it will break loose and you'll have rtv floating around in the cooling system.
Just put it in in the same direction the one you take out is sitting!
Also, don't just put a drain pan under the truck and take that neck off... actually go through the trouble of draining the radiator... it will be much less of a mess! Trust me, coolant can make a huge mess!
Old Jan 24, 2010 | 02:10 PM
95_318SLT's Avatar
95_318SLT
Dang it Felipe, that was twice in a row!!! One of these days....
Old Jan 24, 2010 | 02:18 PM
Crazy4x4RT's Avatar
Crazy4x4RT
LOL! Sucka!
Old Jan 24, 2010 | 02:41 PM
jtdunc's Avatar
jtdunc
Question
Okay - so I have to remove the AC compressor?
How?
I don't think I have AC?
Old Jan 24, 2010 | 02:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If you do have AC you don't have to, but it makes it much easier to do it. Without AC I'm not sure if anything is in the way. Just take a look under the hood.
Old Jan 24, 2010 | 04:32 PM
jtdunc's Avatar
jtdunc
My heater intake hose is slightly in the way but can be moved. With my socket extensions, I think I can get in there. Problem is getting the gasket flat and I think I'll need to drop the stat in the hole.
Adviseable?
Old Jan 24, 2010 | 05:28 PM
95_318SLT's Avatar
95_318SLT
I don't know about your truck Felipe, but on mine the alternator is in the way, not the AC compressor! The alternator is very easy to get off, remove the belt and then 2 bolts and set it aside (you don't have to unbolt all the wires). Taking that off frees up a lot of space!
Old Jan 24, 2010 | 05:37 PM
festerw's Avatar
festerw
You can do it without removing anything it's just a real PITA to scrape the old gasket off of the intake.
If you do when you put it back together you can put the stat in, use some gasket sealer/RTV/whatever and use it to stick the gasket to the waterneck.
