91 Dakota Neutral Safety Switch
Old Feb 7, 2010 | 03:58 PM
mfpudak's Avatar
mfpudak
Default 91 Dakota Neutral Safety Switch
Can anyone with a 1991 dakota 3.9L 5spd confirm if it is equiped with a neutral safety switch
thanks
Old Feb 7, 2010 | 04:25 PM
95_318SLT's Avatar
95_318SLT
What do you mean by neutral safety switch? A park/neutral safety switch is used in autos, and a clutch pedal safety switch is used in manuals.
I know my '95 has a clutch pedal safety switch, but I'd like to say they weren't on the earlier models.
Old Feb 7, 2010 | 04:31 PM
mfpudak's Avatar
mfpudak
I'm wondering if it has a clutch safety switch. The previous owner messed with the ignition and now the truck wont turn over. not sure if the switch may be causing problems
Old Feb 7, 2010 | 04:37 PM
95_318SLT's Avatar
95_318SLT
Look under the dash for a wire harness coming off of the master cylinder. It might be green.
It should look like this (but will be plugged in on the other end).
slidingmastercylintohole2.jpg?t=1265578590
If it is there, there should also be a bypass harness. You can see the bypass harness on mine in the top left corner of the picture (green harness with yellow wires). It will look the same and have nothing currently plugged into it. You could try hooking it up to the bypass to see if it works.
Old Feb 7, 2010 | 04:51 PM
cyclone429's Avatar
cyclone429
if you have cruse control, you have a nutral safety switch
Old Feb 7, 2010 | 06:27 PM
mfpudak's Avatar
mfpudak
I've seen the pic by searching other posts and tryed to find it on my truck. I'm just wondering if the previous owner had removed anything
