94 dakota wont start
Old Jan 26, 2010 | 11:18 AM
cprmn14's Avatar
cprmn14
Default 94 dakota wont start
It turns over, but doesnt fire up. i replaced the distributer cap and rotor, still nothing. so i put some fuel in the throttle body and still nothing.
Last thing i want to do is take it to a shop if its an easy fix, so any advice would be nice.
Old Jan 26, 2010 | 11:32 AM
97Dodge's Avatar
97Dodge
It takes three things for an engine to run. Fire, air, and fuel. I would take out the spark plug and see if there is any fuel on the end of it.
If there is than your getting fuel, next leaving the spark plug out reconnect it with wire. Have someone try turning over the engine with the key. Do not hold the plug or wire. If you see a spark than your getting fire.
If your not getting fuel Might need to change fuel filter and listen to see if your fuel pump is working. If it is not working than you could have a bad relay or fuse or the pump it self could be bad.
Start here and tells us what you find out. If your not getting fire than I have some more ideas.
Old Jan 26, 2010 | 11:55 AM
cprmn14's Avatar
cprmn14
i pulled a plug, forgot to check for fuel on it, but there was no spark. thats when i replaced the cap and rotor. but i checked for a fuel pump and didnt hear anything. but it would have fired when i put fuel in the throttle body right? so you would think spark. but im not sure. and i know the rotor is still spinning so i know the distributer is operating right.
Old Jan 26, 2010 | 12:20 PM
97Dodge's Avatar
97Dodge
Either the pick up coil in the dist. or the ign.coil.
Old Jan 26, 2010 | 12:22 PM
cprmn14's Avatar
cprmn14
does the 94 have the crankshaft positioning sensor? ive looked at some other forums and that seems to be the problem in alot of 91s.
Old Jan 26, 2010 | 01:11 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it does have a crankshaft sensor. First of all there are TONS of possibilities of why it wont start. Like said above you need to narrow it down to Ignition or Fuel. So have you checked your fuel pressure? Did you check to see if the ASD and Fuel pump Relays are working? Did you get any check engine light codes? Did you check all your fuses? Did you look over all of the wires and check for bad spots? There is the notorious splice that is just below the relay box that causes similar problems. Check that.
Old Feb 7, 2010 | 07:18 PM
cprmn14's Avatar
cprmn14
well i just replaced the ignition coil, and still nothing. i know its an ignition problem. i checked the fuses and they look good, i dont see any splices in the wiring under fuse box but i still have to look a little deeper. still open to suggestions. This really has me frustrated!!!
sldfhkshfshfhadohd
Old Feb 7, 2010 | 10:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
This is the post we have in the FAQ. Did you check if you are getting spark. Not just replacing a coil will tell you.
https://dodgeforum.com/forum/1st-gen...ml#post1678925
Old Feb 8, 2010 | 09:29 AM
cprmn14's Avatar
cprmn14
it was that notorious wire splice under the fuse box! i traced them a little more and found it.
any one else having this problem, look for the red and blue wires and you will find it.
thanks for your help guys! helped alot
