Not wanting to start at gas station....
Old Feb 19, 2010 | 08:58 PM
Yeoman3.9's Avatar
Yeoman3.9
Default Not wanting to start at gas station....
filled up with gas the other day, got back in my truck and the booger just wouldn't start didn't even try to start for about five minutes .....then i turn the key all the way off and try again ....busts off like new and runs fine.... any ideas? This is my daily driver sooo i'm a lil nervous...
Old Feb 20, 2010 | 12:26 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You said it did nothing. So did the starter at least turn? Tons of possiblities!
If the starter did turn it could be the power splice. They tend to corode. Check the FAQ in this section for a nice write up on it with pics.
Old Feb 20, 2010 | 02:23 AM
dodgerules86's Avatar
dodgerules86
That splice (the one you are refering to), supplies power to the ASD and Fuel pump relay, not the starter relay.
If the starter did NOT attempt to start, I would look at: battery terminals for tightness, swap the starter relay for a known-good one. Look at the electrical terminals on the starter and make sure they are tight.
If the starter did attempt to start, but the engine just didn't go self-contained, you are possibly looking at the electrical splice mentioned, a bad relay (fuel pump or ASD).
Just naming a few possibilities here.
Old Feb 20, 2010 | 01:40 PM
kahanabob's Avatar
kahanabob
like Crazy ask did it just click click or did it crank over???
Old Feb 20, 2010 | 07:12 PM
Yeoman3.9's Avatar
Yeoman3.9
it cranked over no clicking but no fire ... if that makes any sense...it sounded to me like it was flooded is that possible? cause once i let it sit for a few minutes it started.
Old Feb 20, 2010 | 11:54 PM
dodgerules86
Next time this happens, check for fuel, and spark.
You have a lack of one or the other, it seems.
Old Feb 27, 2010 | 06:09 PM
Yeoman3.9's Avatar
Yeoman3.9
Changed fuel filter .....happened again ...it always happens at the gas station....sat there for ten minutes trying to start the truck ....im at a loss.
Old Feb 27, 2010 | 06:13 PM
Az93DKota's Avatar
Az93DKota
Just by chance did you hit the shifter at any point? Mine has a thing about starting and I always have to make sure to hit the shifter to get it start.
Old Feb 27, 2010 | 06:35 PM
Yeoman3.9's Avatar
Yeoman3.9
called a mechanic friend he said sounds like i need a fuel pump ... cause it tries to start like its getting fire when i turn the motor over but wont stay running...
Old Feb 27, 2010 | 08:07 PM
dodgerules86
Does this only happen after fueling up, or can/does this happen after trying to restart the truck after it's warmed up?
But the truck has no problem running or starting otherwise, correct?
