'94 3.9L cooling problems
Old Apr 28, 2005 | 07:57 PM
nbass's Avatar
nbass
Default '94 3.9L cooling problems
I have a '94 dakota 3.9 L that overheated last summer. Since then I have replaced the radiator, water pump, fan clutch, temp sending unit, thermostats and checked the heads (OK). It will still overheat with a load on it or in the hot weather. The temp gets to 230 deg and in the winter it won't heat up to 195 deg. It will cool down fast and run fine in cool weather, but I have to baby it in the summer.
Any suggestions?
Old Apr 30, 2005 | 02:34 AM
injmopar's Avatar
injmopar
Default RE: '94 3.9L cooling problems
A new thermastat I put in ended up opening to fast and not closing till it cooled down. With the thermastat wide open the water flows through the rad to fast to be cooled. Try hanging yours in hot water to see if it is opening to early. And if it closes on time
Old Jul 15, 2005 | 09:25 PM
Skip's Avatar
Skip
My truck does the same thing. Changed all the above plus the thermastat. Any suggestions? Fuel problem?
Old Jul 23, 2005 | 03:35 AM
clutch's Avatar
clutch
I think its just a dodge problem b/c i have the same problem, and I've changed every thing mentioned too. I have no ideas
Old Jul 28, 2005 | 10:45 PM
gpzjack's Avatar
gpzjack
How about rad caps......They can make you run hot if they are not holding pressure. I have a 96 and the temp is fine......How about bad gagues?
Old Jul 30, 2005 | 01:30 AM
guy1971's Avatar
guy1971
Hd the same problem until I replaced the radiator
