Speed sensor?
Old Mar 8, 2010 | 09:57 PM
Crash0311's Avatar
Crash0311
Default Speed sensor?
While driving home today check engine light came on and my speedometer,mileage and trip quit working. Then started stalling when I come to a stop but starts right back up. All of these started at the same time. Does this sound like the speed sensor and if it does how do I replace it? I bought a repair manual but it doesn't cover it in the book.
Old Mar 8, 2010 | 10:36 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the speedometer and odometer it does sound like the sensor or a wire problem.
The sensor is on the back of the transfer case.
But the stalling doesn't sound like a speed sensor.
Old Mar 8, 2010 | 10:52 PM
Crash0311's Avatar
Crash0311
is it something one person can do alone with limited tools? Do you know where I can get a reference guide online or would it be called something else in a repair manual? Because the Haynes book I have doesn't mention it.
Old Mar 8, 2010 | 11:10 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it is simple to do. Here is a pic. The red arrow it pointing to it.
Old Mar 8, 2010 | 11:58 PM
Crash0311's Avatar
Crash0311
thanks boss, is it just the cable? I only ask because when I researched the part I kept finding magnets and collar. Should I replace these too or do they not usually go bad?
Old Mar 9, 2010 | 12:22 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No it does not have a cable for your year. OEM part number is
5234 422.
When searched on www.autozone.com nothing came up for speed sensor. But a cross reference with the OEM number comes up this sensor. http://www.autozone.com/autozone/cat...e+Speed+Sensor
And I have no clue what you are talking about a magnets and collars.
Edit: Napa had these. The first 2 are what you would need. Depends on which you want to pay for. They are the same just different manufactures.
Old Mar 9, 2010 | 03:09 PM
95_318SLT's Avatar
95_318SLT
The speed sensor is very easy to replace. Count the teeth on the sensor pinion gear. There are numbers written in the 3, 6, 9, ad 12 oclock postions on the sensor... find the number range that the teeth count falls into, and turn the sensor so that that number range is at the 6 oclock position (facing the ground) and bolt down the holder.
I could see where a bad speed sensor would cause an issue coming down to idle. Without the speed sensor working, the computer doesn't know when to have the IAC take over.
I never realized this until I did the manual transmission swap, but when I am coming to a stop, if I throw it in neutral, the IAC holds the engine up to around 1000 rpms and as soon as the vehicle stops moving, drops it down to 600 or so... so obviously, the speed sensor does have input for controlling the IAC.
Old Mar 11, 2010 | 10:44 AM
96kota's Avatar
96kota
is the speed sensor in the same spot on a 2wd manual tranny?
Old Mar 11, 2010 | 12:30 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No not exactly the same spot. Since 2wd doesn't have a transfer case.
But it is on the back of the transmission.
