Shackles or blocks?
Old Mar 15, 2010 | 04:50 PM
will4557's Avatar
will4557
Default Shackles or blocks?
Which one is the best way to lift the rear of my truck, or is there a better way that is still as cheap?
Old Mar 15, 2010 | 05:04 PM
95_318SLT's Avatar
95_318SLT
Well shackles will not lift a 4x4. If you get under your truck and look, you'll see that the shackles are mounted facing upward, so getting longer shackles will actually lower the back.
If you have access to a 2wd dakota, you can swap shackle mounts because they face downward on the 2wd. That will give you a couple inches of lift and better articulation.
Blocks will do it, but all they do is push the axle down. They won't give you any more articulation.
Old Mar 15, 2010 | 06:21 PM
usaweapon777's Avatar
usaweapon777
not to mention extra axle wrap from the blocks
Old Mar 15, 2010 | 07:35 PM
95_318SLT's Avatar
95_318SLT
Very true, but the TBI 3.9L v6 probably doesn't have the torque to wrap the axles
Old Mar 15, 2010 | 08:31 PM
will4557's Avatar
will4557
Ok thanks I havnt looked under the rear so I didnt know if they would fit or not. Thanks for the input guys. I guess I will be going with blocks because I dont have access to a 2wd.
