EGR sensor?
Old Mar 19, 2010 | 03:24 PM
acuffm's Avatar
acuffm
Default EGR sensor?
I had a post on here last week about codes. I have a 96 Dakota 5.2 auto. Did all the tune up stuff and also replaced coil and pick-up coil. All this helped but I still have a small miss at low speed almost at idle. The Haynes Manual troubleshooting section suggests the EGR sensor. I`m not getting an error code that shows anything. My questions are will this sensor show up in check engine and Where is the sensor located? I can`t see anything that resembles the picture in the book and not enough detail to help me locate it.
Old Mar 19, 2010 | 04:22 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The EGR is not a sensor. And if I remember right 96 doesn't have an EGR.
If it is a miss fire it will be a spark plug or the wires. Or a bad fuel injector or a wire problem.
If you can get the code read by a code reader, you can get the exact cylinder that is acting up. Then you can diagnose that cylinder system. You can get it done at more auto parts stores.
Old Mar 19, 2010 | 06:43 PM
acuffm's Avatar
acuffm
I have replaced the wires and plugs. The miss only shows up at a low speed and doesn`t do it all the time. The EGR not being on the 96 would explain why I can`t find it. The code I get from the switch is the 12 which is the power disrupt from unhooking the battery. I`ll try to get to the parts store for a readout tomorrow. It also will run fine if I kick it down and get to higher speed.
