Transfer Case Oil?
Old Mar 25, 2010 | 12:42 AM
Senate427's Avatar
Senate427
Default Transfer Case Oil?
vehicle- 93 Dakota 3.9l V6 4x4 auto 183k
Lately my transfer case has been making a lot of noise at high speeds and I would like to change the oil. So since I know little about transfer cases I was wondering what type oil is best for my TC?
Anything else I should know before I do my first transfer case oil change?
Thanks
Old Mar 25, 2010 | 01:09 AM
95_318SLT's Avatar
95_318SLT
ATF+4.
Very simple job... drain and refill. No filters to change or anything. The drain plug is a 30 mm.
Old Mar 27, 2010 | 08:14 PM
mazda7475's Avatar
mazda7475
saw the picture, try synthetic ( castrol ), your in a cold area. if the seals start to leak refill with regular atf+4, you have too much wear for synthetics.
Old Mar 27, 2010 | 08:18 PM
95_318SLT's Avatar
95_318SLT
ATF+4 is synthetic. There is no such thing as non-synthetic AFT+4.
Old Mar 27, 2010 | 09:20 PM
mazda7475's Avatar
mazda7475
sorry slt i did not know atf+4 was synthetic. i just know it worked a lot better in my 89 then what it called for, of all things that poison Dexron 2.
Old Mar 27, 2010 | 10:50 PM
LO 619's Avatar
LO 619
mazda7475: Chrysler actually has a list of what fluids to use on their automatic transmissions and transfer cases. I wouldn't fool around with any other type of fluid or additive out there atf+4 is only used in Chrysler applications and anything else could cause damage.
Old Mar 27, 2010 | 11:12 PM
mazda7475's Avatar
mazda7475
my 89 dipstick says " only dexron 2 " i have the original manual and it calls for dexron 2 for both the tranny and transfer case. nasty!
Old Mar 27, 2010 | 11:20 PM
LO 619's Avatar
LO 619
Well, if it says dex. 2 then of course that doesn't count lol
http://www.centerforqa.com/licensedatf4brands.html
"Remember, for best performance and vehicle warranty compliance select only licensed ATF+4® for your Chrysler®, Jeep® or Dodge® vehicle. Use of non-licensed ATF brands may damage your vehicle or void your warranty. Please contact us to report unauthorized use of the ATF+4® trademark by non-licensed brands."
Old Mar 28, 2010 | 03:17 PM
mazda7475's Avatar
mazda7475
take lo's advice on this one, don't put anything in your dodge that isn't labeled ATF+4 or synthetic. doesn't matter what the manual says. i cooked that dexron faster than o-rings in a deep fryer.
