Header replacement
Old Mar 29, 2010 | 12:19 PM
Jamuson's Avatar
Jamuson
Default Header replacement
I am looking to replace the whole exhaust system on my 1991 Dakota 3.9 V6. My question is whether or not the newer '92-'96 stock headers would work or not. The '91 is somewhat of an odd-ball year and I want to be 100% sure before I proceed. If they will not work what would be the cheapest option to go with. I am not looking for any performance upgrades or anything, as this truck is gonna be a wood hauling beater. Any feed back towards this would be appreciated.
Old Mar 29, 2010 | 01:25 PM
bill55az's Avatar
bill55az
92 and 93 factory exhaust manifolds would be a good choice, they will fit. 94-99 also fit, but are a tad lower in performance. Not sure about still fitting the Y pipe, tho...
Old Mar 29, 2010 | 02:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm not to sure Magnum will fit on LA's. Some people say it will. But just looking at the gaskets they are slightly different. On the LA's 2 exhaust ports are into 1. So whether or not it will properly seal, I don't know. But here is a picture from autozone. If you wanted have a store pull them up and see if they match up.
1991 Dakota V6 Part#MS93791
1993 Dakota V6 Part#MS95463
Old Mar 29, 2010 | 04:36 PM
bill55az's Avatar
bill55az
It has been done on the v8 engines.....where there is room. A and FMJ bodies are a hard fit. The magnum exhaust manifolds bump into things like linkages, PS, etc. when dealing with a small engine compartment.
It should be easy in a Dakota....
Old Mar 29, 2010 | 09:00 PM
Jamuson's Avatar
Jamuson
I'll check with some local stores this week about the gaskets to see how they will work and provide some update there. Thanks for the quick posts guys.
Old Apr 1, 2010 | 09:13 AM
Jamuson's Avatar
Jamuson
Talked to a few guys locally yesterday and from their suggestions have decided to not try it. A good seal was, in their opinion's rather unlikely and I don't really feel like putting money towards that old crappy engine. So thus I will wait till I get get a cheap '92+ engine for it. Thanks for the advice and input.
