**** ton of work need some input
Old Apr 19, 2010 | 11:26 PM
thebudman84's Avatar
thebudman84
Default **** ton of work need some input
i have a 95 dakota v6 mag 2wd temp gauge keeps bouncing plus i have a ect code so if i could get a location on the ect sensor it would help.
Old Apr 19, 2010 | 11:35 PM
95_318SLT's Avatar
95_318SLT
You have 2 engine coolant temp sensors, so it sounds like they are both bad.
There is a 1 wire sensor that controls the gauge and there is a 2 wire sensor that gives input to the computer.
They are both behind the accessory bracket at the top, front of the intake manifold next to the upper radiator hose.
Its weird that they'd both go out at the same time though! You may want to replace the thermostat while you're at it and flush the cooling system.
Old Apr 19, 2010 | 11:41 PM
thebudman84
well the radiator was replaced in february with brand new coolant but ya. could you get a photo of the sensors?
Old Apr 19, 2010 | 11:44 PM
95_318SLT's Avatar
95_318SLT
This is the best I can offer...
I can't take a picture of my truck cause I have a different intake manifold on it and had to drill and tap one of the holes myself, so it won't look exactly like yours.
Old Apr 19, 2010 | 11:49 PM
shadowthedakota's Avatar
shadowthedakota
i just replaced the one infront of the intake sunday morning...it was a pita cuz of the over crowding issue with wires and such but the pcm controlled sensor is (almost) right behind the ac and the 1 wire sensor is right behind the alt. here is the 1 wire sensor(the bottom circle)
http://i930.photobucket.com/albums/a...p/04152106.jpg
and here is the diagram showing both of them (green being the other one)
http://i912.photobucket.com/albums/a...untitled-1.jpg
you can find them in this thread
https://dodgeforum.com/forum/1st-gen...ad-idle-5.html
Old Apr 19, 2010 | 11:52 PM
thebudman84
there any lift kits fo rmy truck? also know a good place to get a replacement truck bed
Old Apr 20, 2010 | 12:02 AM
95_318SLT's Avatar
95_318SLT
For the 2wd, you can get coil spring spacers for the front (up to 2 inches total), longer shackles for the rear, and a 2 inch body lift. Thats about it.
The best place to get a replacement truck bed would be a junkyard or check craigslist for people parting out these trucks near you.
Old Apr 20, 2010 | 09:40 PM
thebudman84
is it worth converting it to 4wd?
Old Apr 20, 2010 | 09:46 PM
95_318SLT's Avatar
95_318SLT
That really depends. If you have access to a rolling 4x4 frame with transmission, transfer case, and wiring harness, and you really want a 4x4, then yes, its worth it.
Otherwise, I don't think it is.
Old Apr 20, 2010 | 09:48 PM
thebudman84
would i need a new frame altogehter if i wanted 4x4?
