Broke a cv shaft
Broke a cv shaft
I have a 1995 5.2L 4x4 dakota.
Yesterday I broke my front driver side cv shaft. Right now I'm working on removing it and need to know if I can drive in rwd with the shaft removed, without causing any problems. If I go to a junkyard for a new one what years and models share the same shaft?
Thanks.
Thanks.
No you can't drive without the CV shaft. But you can take it apart and just bolt back in the outer shaft (the one with the splines and large nut). If not you wheel hubs bearings WILL fall apart when you first take off. (Brian)
Last edited by 95_318SLT; 04-27-2010 at 08:10 PM. Reason: You misspelled my name! :P
It broke in the outer cv joint so I never had to touch the outer shaft to get the rest of it out. All I found In there were pieces of the bearing cage (no bearings), the bearing hub and joint housing looked fine.
But if you cut off the boot and clean out all the grease, there is a clip you can pull open and the shaft will come apart. Then, again, like Crazy said, you can just put in the outer part. The nut CV axle nut gets tightened to 190 ft*lbs.
