Tranny question.
Old May 6, 2010 | 12:40 AM
shadowthedakota's Avatar
shadowthedakota
1 interesting fact about the 93 though, it never came with a manual v8. only a manual v6 an straight 4.
Old May 6, 2010 | 01:51 AM
the_jones_670's Avatar
the_jones_670
Default re
yea i know that they are the only one with the manual. the 4 cyl i have, manual, the v6 hes bringin out, manual, but my v8 is auto, i cant find hardly any auto trannies here in alaska. so i finally found a 727 for 100 bucks, and thats the route im going.
Old May 6, 2010 | 01:55 AM
Auron's Avatar
Auron
really now i know where to get my next truck i dont like automatics
Old May 6, 2010 | 02:49 PM
95_318SLT's Avatar
95_318SLT
Originally Posted by the_jones_670
a guy just called me and has a good looking and drivin 1993 dakota with the v6 in it, but hes taking the engine out and offered me the truck, its 4x4 and has a stick tranny, so what are the odds that tranny will run for a while? im not sure what tranny it is, but the truck is free, compared to spendin money on the tranny.... would it be worth it to swap the engine???
yea i have a v8, but i figured id still just get the truck and end up buyin a nv3500 and switch them the tranny in when i get it and do the engine swap.
i will have all three versions of the dakotas then lol. but my v8s got a chopped frame, my 4 cyl doesnt have an engine. so i figure ill get rid of the 4 cyl, get the one the guy offered me and right now im just goin with the 727 and drive the truck. thanks for all you help.
I would personally go that route!! The ax-15 will last a while if you don't race the truck every day! The most likely point at which the v8 would tear through the ax-15 is WOT at 3200 rpm, so if you avoid that, it should last a while. If you threw your engine in the v6 4x4 5 speed, you wouldn't be loosing anything except some time. It would be easier to swap the engine into the truck that is already a manual now and change transmissions to the nv3500 later than to swap in a manual into a truck that is currently an automatic.
And, since you won't have any money in the above project, you could always get the 727 as a backup just in case the ax-15 goes out before you can find an nv3500. Then you could sell the 727 when you find the nv3500 and decide you don't need it.
What do you mean by chopped frame?
Old May 6, 2010 | 02:52 PM
the_jones_670
Default good news
that tranny im lookin at is off a 360 so i should be good right.
Old May 6, 2010 | 03:00 PM
95_318SLT's Avatar
95_318SLT
It will bolt up to your 5.2, but you are going to have to buy a new, neutral balanced torque converter to put in the transmission. The torque converters that were in transmissions behind 360s back then were balanced for the engine.
I still say get the 5 speed v6 4x4! :P
Old May 6, 2010 | 03:09 PM
the_jones_670
Default re
i just got the v6 truck towed out here. im just going to put it aside for now and slowly work on it buildin the drive and runnin gear. i plan on ending up puttin a built up 360 in it. for now i am gettin the 727 and put it in my v8. quickest route i think considerin i dont have too much money, and i dont have all the means for the engine swap off hand. still very muddy around lol. and by the frame being chopped, is that when i got it i looked under it and it had about 3 inches missin out of the rear fram and a peice of 3/4 square stock tubin welded in place....very poorly...and with a bigger shock on oneside lol. Being what it is, i didnt pay very much for the truck. but the engine is a freshly and trusted rebuild.
Old May 6, 2010 | 03:13 PM
the_jones_670
Default torque converter
my stock torque converter wont bolt up??? out of the a518? just curious seein as how i already have it. and i planned on maybe getting a shift kit, tranny filter kit, and a cooler of some sort dependin on how much it is. i just got laid off and am on unemployment till the truss plant opens back up. so i dont have much to work with between this and rent. lol
Old May 6, 2010 | 03:15 PM
95_318SLT's Avatar
95_318SLT
Hmm, thats a good question. I don't know if it will bolt up or not. I guess you could compare the two and try. Let us know whether it does or not!
Old May 6, 2010 | 03:18 PM
the_jones_670
yea seems like it should work. hopefully lol it be nice to get it goin quick like lol. i wanted it for the winter because we have ice races but wasnt that lucky to find a tranny lol.
