1993 dodge dakota tranny problem
Old May 12, 2010 | 03:27 PM
chazzychaise's Avatar
chazzychaise
Red face 1993 dodge dakota tranny problem
now iv heard that dodge trannys are bad.. i have a 93 dodge Dakota and after i heard that like 3 mouths ago .. it started acting up. it leaks all the time.. i have to put a gallon of oil in every two weeks and its still not full after that.. and now i have no fifth gear.. would like some help on what to do about it and if so were i can get a new 5-speed tranny for a cheap price..
Old May 13, 2010 | 01:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The automatics are Dodge transmissions. The 5-speed manual transmission AX-15 that came on both V6 and 4cly is made by a different company called Aisin Warner.
The best place to find one for a cheep price is junkyard or www.ebay.com or www.craigslist.org
Also it is best if you post int he 1st Generation Dakota Sub-Forum. I will move it there.
Old May 13, 2010 | 01:49 PM
Az93DKota's Avatar
Az93DKota
Where's the leak coming from?
BTW, I had mine rebuilt after it self destructed 3 years ago and had all the upgrades done to it. There were weak links in the trans but newer parts are made a bit better then they were 17 years ago.
Old May 13, 2010 | 02:43 PM
95_318SLT's Avatar
95_318SLT
Like Crazy4x4rt said, dodge only makes the auto transmissions they use. You didn't specify if you have a 4 cyl, v6, or v8, but again like he said, the 4 cyl and v6 use the Aisin Warner AX-15. The v8 uses the nv3500 made by New Venture Gear. All of the big 3 american companies use New Venture Gear products, so you can't chalk it up to Dodge if it breaks!
*EDIT*
Lol, nevermind... I just rememebered there was no v8 5 speed combo in '93, so Crazy4x4rt is right, you have the AX-15.
Old May 14, 2010 | 12:55 AM
Auron's Avatar
Auron
i have a 96 with the ax 15 and the tranny is perfect but the engine i think will crap out on my soon my old truck was a 97 f150 with a jasper engine that thing was bullet proof i could and did redline it all the time without a problem but it wasnt mail box proof
hitting these @ 65 tends to put a damper on your plans for the day
and thats the story of why i now own a neat little soon to be 6x6 4bt dakota flat bed due to be done in the next 18 months
Old May 14, 2010 | 01:02 AM
95_318SLT's Avatar
95_318SLT
Huh, I've never heard anybody call out one of these engines (3.9, 5.2, 5.9 family)!! I've always considered them to be bulletproof! I've had my truck over 2 years now and drive the **** out of it every time I go somewhere and it still starts without hesitation and doesn't leak, burn or use any oil!
Old May 14, 2010 | 01:24 AM
Auron's Avatar
Auron
3.9 the old owner went 3 years without changing the oil im about to change it again for the 5th time in since feb. cause its black again and i usually redline before i shift im not nice to it
Old May 14, 2010 | 01:39 AM
95_318SLT's Avatar
95_318SLT
3 years without changing the oil and its still running... yup, I was right, they're bulletproof :P
Old May 14, 2010 | 01:47 AM
Auron's Avatar
Auron
i see what you mean but it wasnt a daily driver at that point and the oil is still turning black after 5 seperate oil changes and seafoam treatments and i have a pully bearing that is failing
Old May 14, 2010 | 02:06 AM
95_318SLT's Avatar
95_318SLT
You realize that with the detergents in modern oils, they turn black pretty quick? It doesn't mean the oil needs changing, it's just how the detergents react.
