92 dakota 4x4 engine swap
Old May 18, 2010 | 12:54 AM
dakotaredneck's Avatar
dakotaredneck
Default 92 dakota 4x4 engine swap
ok guys i have a 1992 dodge dakota with a 5.2l 318 magnum i was wantign to swap it out for a 5.9 and was looking from you guys on what year i should git and what i will run into with clearance issues if any i plan on building the motor before installing and was also wondering about transmission improvements i might or should make and possible suspension mods the i will need to make. and also if anyone knows a of a site that offers a lift kit for these trucks
Old May 18, 2010 | 01:15 AM
95_318SLT's Avatar
95_318SLT
The 5.2 to 5.9 swap could not be easier. You need a bare minimum of a 5.9L short block, weighted flex plate and PCM. Your current motor mounts, wiring harness, heads, intake, oil pan, accessory bracket, etc. will all swap over. If you get a complete 5.9L, you may still need your intake manifold and oil pan depending on what it comes out of.
As far as where to look, any Dodge truck or Jeep GC with a 5.9 in it from '93 until they quit making them will work.
As far as the transmission, no upgrades are needed as the 46rh came behind 5.9s from the factory.
Suspension mods are also not neccessary because the 5.2L and 5.9L are the same engine from a size and weight perspective... only the internals are different.
Check the faq2 page for lift stuff.
Old May 18, 2010 | 04:03 AM
Az93DKota's Avatar
Az93DKota
I was told by a friend that you can swap the heads off a 5.9 onto the 5.2. But have to make sure your clearances are in spec. He says he can do it to mine no problem. Question is, is this something I wanna see at someone elses expense? It would be free if I let him. IDK
Old May 18, 2010 | 11:41 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes you can. But droping in the 5.9 will add in more power then just the heads alone.
Old May 19, 2010 | 08:56 PM
dakotaredneck
i also plan to build the motor befor instaling so i would like some ideas from u guys out there i already plan to make it a 408 stroker and git some 1.7.1ratio rocker
Old May 19, 2010 | 09:08 PM
95_318SLT's Avatar
95_318SLT
If you are talking about building a 408 and putting in 1.7RR with a factory cam... don't! That would pretty much be a waste of money. You can get more power out of a 360 with a big cam than you can with a 408 and factory cam. Keep in mind that the heads/cam/valvetrain are what makes and breaks an engine!
Old Jun 18, 2010 | 12:09 AM
dakotaredneck
no heads cam and valve train will all be repalced the only thing im realy useing is the block this is the kit im ordering http://speedomotive.com/ps-140-13-mo...roker-kit.aspx
