Hockey Puck Lift
Old May 21, 2010 | 10:40 PM
95_318SLT's Avatar
95_318SLT
I didn't make any modifications to my 5 speed tranny shifter with the 2 inch body lift and it works just fine!
I did make a completely custom, one-off transfer case shifter.
But yes, the lower radiator hose needs to be shortened. I don't think there were any upper radiator hose mods that I had to make. I actually took the opportunity to install the electric fan rather than trying to make the mechanical fan fit.
Here is a picture of the transmission shifter un-modded with a 2 inch body lift...
InteriorAfter.jpg?t=1274495946
And here is my custom transfer case shifter...
Old May 21, 2010 | 11:10 PM
Auron's Avatar
Auron
my custom front end replacement is welded into the frame so that wont matter and how would i relocate the shroud
edit: your truck is so clean looking
Old May 22, 2010 | 02:07 AM
Crazy4x4RT's Avatar
Crazy4x4RT
For me doing it 2 times it didn't need to be shorted. Once 2wd and Once 4wd.
Ya defiantly the electric fan is a good upgrade. But simple brackets can be made to shift the fan shroud instead of cutting it up.
