monday stroll gone wrong
Old May 24, 2010 | 09:48 PM
Big_Phil's Avatar
Big_Phil
Default monday stroll gone wrong
well i was ridin around the sand pits here, and found a small hole. it was deeper than i thought, and when i tried to push through it, my rear diff got hung up and my front end burried under some mud.
we get the truck out and everything seems fine. but my oil pressure seems to be a little outta wack. i just replaced the pump and switch a few weeks ago. the pressure was fine before the sink hole and now it is low. its still in range but its lower than usual. there is no sign of water in the oil.
anybody have any kind of help.
Old May 24, 2010 | 10:10 PM
sammatthews2007's Avatar
sammatthews2007
I've noticed whenever I brake hard my oil pressure drops - maybe because the oil is being slammed up against the front wall away from the gauge?
It will then level out again later.
Old May 24, 2010 | 10:28 PM
Big_Phil's Avatar
Big_Phil
see mine was doin that before my pump and switch change. after that it was fine and now this.
Old May 24, 2010 | 10:40 PM
Big_Phil's Avatar
Big_Phil
u think it could be the oil weight? i have 20-50 in it right now. u think if i switched to 10-40 or 10-30 it would fix it?
Old May 24, 2010 | 11:32 PM
shadowthedakota's Avatar
shadowthedakota
isn't it supposed to be 10w-30. thats what the manual says.
Old May 24, 2010 | 11:35 PM
sammatthews2007
I prefer 10-40 these days - mainly because my engine is older.
Old May 25, 2010 | 10:52 AM
Big_Phil's Avatar
Big_Phil
im gonna put 10-30 in on the next oil change. the 20-50 was doin fine till i got stuck. im thinkin my switch might of got wet.
Old Jun 1, 2010 | 04:40 PM
melodytoinvent's Avatar
melodytoinvent
My oil pressure drops like then when its low and needs a change, but other than that, no idea.
Old Jun 1, 2010 | 05:21 PM
LO 619's Avatar
LO 619
Yeah, it is. But you are supposed to go up in weight as the milage increases to compensate for engine wear.
Old Jun 1, 2010 | 05:22 PM
LO 619's Avatar
LO 619
You could always do a 50/50 mix.
