hooking bumpers
Old May 30, 2010 | 03:38 AM
Auron's Avatar
Auron
Default hooking bumpers
a buddy of mine wants to hook bumpers when i finish rebuilding my motor
what he has :2002 dodge dakota 4x4 4 door slt automatic v6? (he said he didnt know cause he never looked he doesnt know the first thing about cars anyways) highway tires about 29 inches tall
what i have : 1996 dodge dakota 4x4 ext cab manual v6 all terrain snow/mud tires about 31 inches tall
he is a buddy from school that i grad. from on friday and he just moved up to be a senior in the up coming year i doubt he knows what 4 lo is but i want to know my chances of winning in case he does cause i dont like to lose and the place is a dirt field by the lake and any tips to win this
Old May 30, 2010 | 11:06 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm guessing your going to be doing a Tug O War kind of thing just going forward.
The best tip is to use your brakes at the beginning. When he starts to spin, where he loses traction. Then you hit the gas at a steady pace. Do not spin your tires.
You can of coarse put it in 4wd or even 4low.
Just as a warning there is always a chance of breakage due to these trucks not built for O Wars.
Old May 30, 2010 | 09:51 PM
Auron's Avatar
Auron
yes a tug of war and thats why the use of the dirt lot to reduce the chance of breaking something
Old Jun 1, 2010 | 04:51 PM
Bump's Avatar
Bump
sounds like a bad plan... just sayin...
But yes, the minute he spins, all his traction will be over come. On the other hand, if you start to be drug, you lost already.
using chains? be sure to weigh them down at 2 places to prevent back-lash if they break or desconnect from the truck.
Old Jun 1, 2010 | 08:54 PM
Josh Abels's Avatar
Josh Abels
it'll prolly be really even, trucks weigh about the same and prolly have close to the same amount of power
it'll all come down to traction
u'll prolly win with ur tires, if he's got the stock 29's on the truck they will most likely be goodyear eagle ls tires and they are highwayers
Old Jun 1, 2010 | 09:14 PM
95_318SLT's Avatar
95_318SLT
I'll be here when you get back to help you through a transfer caes rebuild! :P
But in all seriousness, you will probably win if nothing breaks. Same engine, but you will be putting more power to the ground with your manual transmission (as long as you don't stall it). And with street tires, I don't see him being able to bite the dirt at all.
Old Jun 2, 2010 | 12:31 AM
Crazy4x4RT's Avatar
Crazy4x4RT
A good hint! Lower your air pressure in your tires. This will increase your footprint for increased traction. And if you have it low enough the less roundness of the tire will help you from slippage. If you don't have drive to far to get to the challenge spot go as low as 10-15psi. (Don't let anyone know you did it.)
Now that Josh Abels brought up weight. He will be heavier. According to Mopar Action Magazine the 2nd Gens are 100-200lbs heavier. That is both reg cabs long beds. And with him a 4 door that is extra weight. So that will give him a slight advantage.
Old Jun 2, 2010 | 08:02 AM
tmacdakota's Avatar
tmacdakota
Or you could just say take a hike bro' and save some possible breakage on your truck.
Old Jun 2, 2010 | 09:02 AM
Auron's Avatar
Auron
thats no fun buzzkillington i havent seen you around here, oh and @ crazy i also have a campershell, toolbox, and the diamond plate bumber i made as weight
Old Jun 2, 2010 | 09:04 PM
tmacdakota's Avatar
tmacdakota
more stuff to break...goody.
