OK, I have to ask.
Old May 31, 2010 | 12:41 AM
Az93DKota's Avatar
Az93DKota
Default OK, I have to ask.
Some local Jeeper stopped me at the store the other day and said something that has been bugging me. He told me that his 93 Wrangler 4.0 is being ran by a 5.2 ECM that was out of a wrecked Grand Cherokee. Is this possible?
Old May 31, 2010 | 01:03 AM
shadowthedakota's Avatar
shadowthedakota
not sure if the the 4.0 is a v8 but if it is i would assume so...
im not to familiar with the different motors other than the 2.2l, 2.5l, 3.9l, and the amazing 5.2/5.9l
Old May 31, 2010 | 01:26 AM
Az93DKota's Avatar
Az93DKota
Yeah, I am having a hard time believing this. Cause he didn't have a sticker on the ECM to get the numbers off of it to find out if it was for a 5.2. But they do have the same ECM connector.
Old May 31, 2010 | 01:42 AM
dbilik's Avatar
dbilik
The 4.0 is an inline 6. A V8 ECM should not run it properly.
Old May 31, 2010 | 01:43 AM
95_318SLT's Avatar
95_318SLT
That is 100% total BS. IIRC, the 4.0 is an inline 6 right? There is no way a v8 computer could run an I6. Different timing tables, different fuel maps... absolutely impossible.
If you see that guy again, tell him to turn in all his tools cause he needs to never work on a vehicle again!
Old May 31, 2010 | 05:05 AM
shadowthedakota
sorry to be off topic but there is a person over here trying to sell off a v8 dakota sport with a ax-15 manual in it saying it came that way from the factory....btw its a 93
Old May 31, 2010 | 10:19 AM
will4557's Avatar
will4557
I didnt think the V8's came with a manual trans as an option in 93. The AX 15 was the manual trans that came in the 4cyl and v6's. The v8s only came with automatics from the factory in 93. If I can remember right that is what the faq said in this section.
Old May 31, 2010 | 01:21 PM
95_318SLT's Avatar
95_318SLT
^ Yup. There was no v8 5 speed option until '94. And the AX-15 never came behind the v8... its too weak. In fact, the v6 5 speed Ram even had the nv3500 cause the weight of the truck was too much for the AX-15.
Old Jun 1, 2010 | 12:08 AM
shadowthedakota
i knew about the 93 v8 being only auto. i found that out in research i did for the swap on mine. the person swapped teh v8 into the truck i know for sure. because in the search done on the vehicle the trans numbers match what the manufacturer had tagged.
Old Jun 1, 2010 | 12:37 AM
Auron's Avatar
Auron
you dont always have to be gentle... but in the case of that truck i would be untill an nv3500 is put in
