Probly really stupid question. Just frustrated.
Old Jun 2, 2010 | 04:44 PM
the_jones_670's Avatar
the_jones_670
Default Probly really stupid question. Just frustrated.
Ok so im working on changing my tranny....very tight quarters where im working also....but i have every bolt out except two along the top of the tranny. Why cant i get the torque converter inspection plate out. its loose will move around, a little bit. but it wont come out. any help. its a 1992 dodge dakota v8 magnum, auto tranny. i need it out of the way so i can grab the bolts for the torque converter and get it the hell out.
Old Jun 2, 2010 | 04:56 PM
95_318SLT's Avatar
95_318SLT
Hard to say. Can you get a picture of it?
Old Jun 2, 2010 | 05:08 PM
Bump's Avatar
Bump
When I did my motor swap that was one of the more difficult parts to get out and get back in. If I remember right, I got those two bolts from the top, but it was like an 1/8" turn at a time!
Old Jun 2, 2010 | 05:30 PM
Crazy4x4RT's Avatar
Crazy4x4RT
For the TC dust cover I believe the starter has to be removed. As for the top transmission bolts a ratchet wrench does the trick.
Old Jun 2, 2010 | 05:55 PM
Az93DKota's Avatar
Az93DKota
I do believe that the converter bolt and the plate only line up one way. So make sure you mark the 2 for easy installation later.
Old Jun 2, 2010 | 11:58 PM
the_jones_670
So i got the transmission all the way out now, but i didnt even think about marking the flexplate and torque converter. Whats the damage? Wouldnt of mattered anyway the tranny i got for it came with a torque converter...not marked either
Old Jun 3, 2010 | 12:11 AM
Az93DKota's Avatar
Az93DKota
Just makes it easier to reinstall to line the holes back up. Cause you'll put a bolt on and turn it to the next hole. Then realize they don't line up.
Old Jun 3, 2010 | 01:26 AM
95_318SLT's Avatar
95_318SLT
^ yup. The only problem you now have is it will take longer to put back in. The flex plate can only bolt to the torque converter one way, so you could get 2 or 3 bolts in and have to start over because its not oriented right.
Old Jun 4, 2010 | 02:43 PM
fox87's Avatar
fox87
you might look into a new tork converter. i put an old one in a truck i used to have and the dumb ..... that pulld it droped the converter and got oil clean up crap in it and didnt tell me and it tore the trany up and i had to get another. just a fyi. do it right the first time so you dont have to do it again
