AC issues
Old Jun 23, 2010 | 01:48 PM
Wishihadahonda's Avatar
Wishihadahonda
the cowl cover or the under dash cover?? idk how to get to it under dash any threads on it? im at work i can search when i get home i guess
Old Jun 23, 2010 | 02:35 PM
Joezilla64's Avatar
Joezilla64
To get to it I took out the glove box and then you can see the cover. On the right of the heat/ac housing you should be able to see the recirculation door. This is part of the cover. When you get it off don't forget to reach through the hole above the fan where the outside air comes in. There will be a lot of junk in there.
Get some 1/2" wide foam weather stripping from home depot so you can seal the cover when you're done.
Old Jun 23, 2010 | 07:49 PM
Flying's Avatar
Flying
Do you think you have a Honda or Toyota? There is no cabin air filter!
